It is currently Fri Jul 18, 2025 11:41 am
 Post subject: 850 fuel tank sender fix
PostPosted: Mon Jan 15, 2018 5:17 pm
Hi all. I have a friends mini i am repairing. It has an 850 fuel tank fitted and the sender is not working. Its the one that is held in with several screws. Yes the guage is working ok. Has anybody fixed these as it seems new ones are not available.
Cheers Ian.
PostPosted: Thu Jan 18, 2018 8:18 pm
Hi Ian, I had a couple of useful bits of advice offered after I had a similar problem. Try John Schmidt at Mini Kingdom for advice on how to maybe fix your unit. Alteratively, someone like Rodger Howard at Howard Instruments should be able to repair and recondition the unit for you.
viewtopic.php?f=2&t=95039&hilit=850+sender+fix#p1017966
I do recall finding a good article on an MG forum about a guy who rewound his own sender. Here is a link:
http://mgaguru.com/mgtech/electric/et214.htm
If you are game and a bit handy, it looks like it is feasible to rebuild one yourself.
Tartanred
PostPosted: Thu Jan 18, 2018 8:34 pm
Are you using the matching fuel gauge? The senders with the screws were non-stabilised, I don't think you can mix them?
PostPosted: Thu Jan 18, 2018 8:40 pm
Thats what I was thinking. 10volt Vs 12volt
Ian, There was a good discussion on the MK1-forum and how to identify the various types by their ohms readings. http://mk1-forum.net/viewtopic.php?f=3& ... 6b91b50ade
PostPosted: Thu Jan 18, 2018 8:45 pm
Guys,
Thanks for the replies. We have a new speedo and gauges fitted with new voltage stabilizer. The guage did not work with the old speedo either. When the wires are joined (at the tank) the guage reads full.....
I will read into this a little more.
Ian
PostPosted: Thu Jan 18, 2018 9:01 pm
Does the float float?
PostPosted: Thu Jan 18, 2018 10:25 pm
Ian, I think I see your problem - the type of sender you have (six screws) worked on a 12v non-stabilized system. You have said you are using a voltage stabiliser gauge setup. They are not compatible. You need a later tank and sender unit (which fortunately are much more common than the early setup at least...). Or else you need to revert to an early fuel gauge and eliminate the voltage stabiliser.
PostPosted: Fri Jan 19, 2018 10:38 am
I've never done it, but I'm told that you can drill holes around the edges of the later sender to fit it to an early tank.
Roger Howard repaired the early sender for my Traveller. It had a burnt out coil, charred black (that can't be good inside a fuel tank!). I'm not sure how he did it, he must have sourced a correct replacement coil from somwehere. It works a treat now.
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
Users browsing this forum: Bing [Bot] and 102 guests
