It is currently Wed Jul 16, 2025 9:39 pm
 Post subject: Valve stem seals/o-rings
PostPosted: Sat Jan 13, 2018 12:29 pm
Rebuilding the 202 head and have put new valve guides in with a groove to take conventional valve stem seals. What do the small o-rings which came in my gasket set do? Do I need them when I run the other seals? Thanks
1972 Mk3 Mini 1000, 1150cc supercharged.
https://www.ausmini.com/forums/viewtopic.php?f=3&t=95872
PostPosted: Sat Jan 13, 2018 12:38 pm
PostPosted: Sat Jan 13, 2018 1:27 pm
MinisPlus
The O ring seals don't get used when fitting the S type (on the right of pic).
You can chuck the o rings if you want, they don't work very well, the S type is the way to go.
Always check the caps don't hit them if you are using long collet valves and high lift cam.
How can it be rusty when it's covered in so much oil?
PostPosted: Sat Jan 13, 2018 1:44 pm
And also make sure the groove fits the seal. I have had to machine off part of the guide to allow the seal to fit before.
1963 Morris 850 Smoke Grey
1963 Morris 850 Shadow Blue
1965 Morris Mini Smooth Van
1966 Morris Mini Van
1969 Morris Mini Deluxe Resto
5/72 Clubman Gt
PostPosted: Sun Jan 14, 2018 6:33 am
Don't the O rings only fit early mini's with the long collet groove?
PostPosted: Sun Jan 14, 2018 7:12 am
Yes. I would fit them in, they help stabilize the early collets.
I have used the 1275 seals on plain smallbore guides by smearing some 262 Loctite on the guides.
PostPosted: Sun Jan 14, 2018 7:56 am
Are the 1275 seals different?
Where exactly do the o-rings fit? cheers
PostPosted: Sun Jan 14, 2018 9:10 am
You fit them in collet....sort of.
PostPosted: Sun Jan 14, 2018 9:38 am
Part 19 in this exploded diagram of a 998 head.
PostPosted: Sun Jan 14, 2018 10:31 am
You fit the O ring into the valve stem groove when spring is compressed, then fit both collets on top of it.
Only used on early valves with the wide collet groove.
PostPosted: Sun Jan 14, 2018 10:53 am
Thanks guys
PostPosted: Sat Jan 27, 2018 1:39 pm
Copper side up?
PostPosted: Sat Jan 27, 2018 4:53 pm
Generally yes.
Copper gaskets aren't as good as in the old days, if you get water leakage fit a BK450 composition one instead.
PostPosted: Sat Jan 27, 2018 6:40 pm
thanks mate, I have another gasket (looks like a black and silver one) perhaps I should just fit that?
PostPosted: Sat Jan 27, 2018 6:49 pm
Try it.
