It is currently Thu Jul 17, 2025 10:21 pm
PostPosted: Mon Jan 01, 2018 3:40 pm
There was discussion on the internet about the vapor at the intake ports. Most thought it was fuel. Actually it’s water vapor in the air made visible by the low pressure zone created by tremendous intake vacuum. The same thing can be seen on the upper surface of a jet’s wing under high lift conditions. Those ports are sucking so hard they’re making their own clouds. Cool!
https://www.facebook.com/PoserMotorSports/videos/1766784153394253/
Michael, Santa Barbara, CA
. . . the sled, not the flower
PostPosted: Mon Jan 01, 2018 4:21 pm
Cool pics!
So that's where my Dellorto's carb icing probably comes from then. :)
PostPosted: Tue Jan 02, 2018 3:56 am
Cool pics!
Could be...
PostPosted: Tue Jan 02, 2018 11:29 pm
Ahh the low pressure condensation...here is a link with lots of it. The F15 is cute...F14 looks a lot sexier and does it better :D
Long vid but pure horn to a navy combat systems manager...
http://youtu.be/QCmEFrWDAUY
Btw...love the Arden heads...
Rob Forsyth
Miniot!!
PostPosted: Wed Jan 03, 2018 4:06 pm
Love it :D
PostPosted: Wed Jan 03, 2018 4:16 pm
I must admit I had no idea 850's competed at Bathurst! I thought their top speed was about 75 mph? i would have thought brake fade would have been a huge problem with drums all round doing loads of laps around Mt Panorama? Maybe because they handled so well they didn't use the brakes, engine braking only?! Those early gearboxes must have been tough to put up with the abuse...?
67 Deluxe
Dry suspension
4 synchro close ratio gbox
Cooper S brakes, no booster
PostPosted: Wed Jan 03, 2018 5:40 pm
Early 850 gearboxes were rubbish I had a '61. You were lucky to get 8000 miles out of 2nd gear's brass cone synchro.
It wasn't until 1963 that they got baulk ring synchros here in Oz.
PostPosted: Wed Jan 03, 2018 8:03 pm
Didn't think so by your comment...I think the VWs had better brakes and ran stronger but maybe didn't handle as well...the Mini's were light, so brakes were adequate :D
https://www.youtube.com/watch?v=VdbAG9j1418
