It is currently Thu Jul 03, 2025 6:58 am
 Post subject: Micks hydrolastic pump
PostPosted: Mon Jan 01, 2018 5:27 pm
Seven years ago Mick posted a great "how to build hydro pump " using a bulk grease pot. He used a Schrader coupler to attach the delivery pipe to the Schrader valve.
I went to use my copy of his pump to day for the first time and realized it is impossible to screw this Schrader coupler to the valve on the rear sub frame. That's because the inlet to the valve is at right angles and therefore needs clearance to the sub frame to be able to screw it on.
Can anybody who has used this connector tell me how you fitted it to the valve?
Mk1 Cooper S
Mini K Rally car
PostPosted: Mon Jan 01, 2018 8:08 pm
Gday Crisonic,
If you look at the Chuck I have used, identical to this one, you will notice that the brass nut turns. This means you only need a spanner to screw it on to the right angle Schraeder valve.
PostPosted: Mon Jan 01, 2018 8:57 pm
I dont even use a spanner. I spin the nut up finger tight and the last 1/8th turn i get by turning the entire chuck assembly.
PostPosted: Tue Jan 02, 2018 12:44 pm
I had no idea that the nut turned.
I cannot thank you both enough
I had drawn up a small brass block with male and female connectors so that I could turn the Schrader valve around 90 deg and have it poking out the back
Many thanks again
Mk1 Cooper S
Mini K Rally car
