It is currently Thu Jul 10, 2025 2:10 pm
PostPosted: Sun Dec 31, 2017 10:54 am
Hi guys. Got a weird sound from the cooper S its got a grinding noise. And almost like a loose front wheel sound but no vibration from the wheel I have checked them and they are tight... any sugesstions. Thinking bearings...
PostPosted: Sun Dec 31, 2017 1:12 pm
Get a mate, jack it up and wriggle the wheels. Look/ feel for things/ play that shouldn't be there. Anything drastic will be immediately obvious....
67 Deluxe
Dry suspension
4 synchro close ratio gbox
Cooper S brakes, no booster
PostPosted: Sun Dec 31, 2017 2:10 pm
yeah, I ended up doing that. and turned out the 4 Allen screws were loose on the hub
PostPosted: Sun Dec 31, 2017 3:04 pm
A mate had the same problem this week.
I use an impact driver on them. ;)
PostPosted: Sun Dec 31, 2017 3:11 pm
I just used a ratchet. Hopefully thats good enough... It's been loose for quite a while. I just kept removing the wheel nuts and putting them on.. it seems to do the trick for a while... Hopefully this is the actual fault.
PostPosted: Sun Dec 31, 2017 7:27 pm
We fitted a new drive flange but the old one looks fine.
