It is currently Mon Jun 23, 2025 9:18 am
 Post subject: RE 1098 pistons
PostPosted: Tue Dec 19, 2017 5:16 pm
Hi all,I need advise.Im building 0'80" overbored 1098 to my van.I also have a nice 12G202 with bigger valves etc.It's been skimmed and the chamber volume is 24cc.I need to get compression ratio down to 10:1.My question is how much there is meat on top of these pistons? Is it possible machine dishes which are about 5cc?
Tomi
 Post subject: Re: RE 1098 pistons
PostPosted: Wed Dec 20, 2017 4:25 am
Don't machine the pistons, open the chambers out around the valves for better breathing.
Edit
And if running 98 fuel you can go to 10.5:1 or so.
Last edited by drmini in aust on Wed Dec 20, 2017 5:46 am, edited 1 time in total.
PostPosted: Wed Dec 20, 2017 5:44 am
Thank's for reply.I dont know is there enough metal left for 5cc.I have to check piston to deck height.
PostPosted: Wed Dec 20, 2017 5:48 am
You can make those chambers much bigger.
[edit] When decking these old heads it's wise to stop at .075". The deck is thin in places with corrosion and won't clamp the gasket well if you rip more off.
Last edited by drmini in aust on Wed Dec 20, 2017 8:17 am, edited 1 time in total.
PostPosted: Wed Dec 20, 2017 5:54 am
Ok.So i leave pistons alone and start to work with head. Thank's Doc.
Tomi
