It is currently Tue Jul 15, 2025 10:39 am
 Post subject: Cooper S Ashtray spring
PostPosted: Thu Nov 30, 2017 12:56 pm
Could somebody please show me what the spring looks like? I don't have one and I'm getting tired of the lid flying off when I hit a bump :-(
No smoking in my car, I could glue in somehow I suppose...
Thanks
Michael
67 Deluxe
Dry suspension
4 synchro close ratio gbox
Cooper S brakes, no booster
PostPosted: Thu Nov 30, 2017 12:59 pm
Blu Tac mate.;)
PostPosted: Thu Nov 30, 2017 3:02 pm
I'll take a look at mine and take a pic when I get home. I think it's pretty basic like a piece of bent spring hard wire.
PostPosted: Thu Nov 30, 2017 8:11 pm
Mig welding wire may be the answer.
PostPosted: Fri Dec 01, 2017 5:43 am
It would have to be Cooper S spec wire. :D
PostPosted: Fri Dec 01, 2017 6:04 am
Winabbey probably has a part number for it LOL! 2 threads on the same page about ashtrays is a bit odd!
67 Deluxe
Dry suspension
PostPosted: Fri Dec 01, 2017 7:28 am
Not really, this post got me looking at my ashtray collection.
PostPosted: Fri Dec 01, 2017 8:34 am
What else do you collect?! LOL!
67 Deluxe
Dry suspension
PostPosted: Fri Dec 01, 2017 9:05 am
engine numbers by the looks...
PostPosted: Fri Dec 01, 2017 3:50 pm
In the Cooper S ash tray there's a small spring at each end. I'm guessing yours has neither.
Michael - If you want it you can have the complete ash tray pictured. I'm in Carnegie so not far from you. PM me and I'll give you my address so you can drop by to collect.
PostPosted: Sat Dec 02, 2017 11:10 am
Maybe there were variations on the lidded ashtrays too.
Mines not like that. It has a wire hinge like the fluted style and rather than springs either end the bit you stub out on acts as the "spring". Mine looks old enough to be original ....but who knows.
PostPosted: Sat Dec 02, 2017 11:25 am
The one I pictured came with some other spare parts so may not be legit for the Australian S.
The part number is 24A1538 and doesn't appear to have an Oz equivalent so maybe not enough volume to justify local production.
PostPosted: Sat Dec 02, 2017 1:08 pm
The ashtray pictured is identical to the one I removed from an Oz Cooper (not 'S') I had in the '80's. Forget the year but early, had sliding windows. Having said that, I suspect Cooper's were phased out by the time wind up windows arrived...? So I'm pretty sure the above was fitted to Oz cars at some stage.
67 Deluxe
Dry suspension
PostPosted: Sat Dec 02, 2017 3:00 pm
My '66 S has a lid spring as Phillb describes, made of pressed spring steel and a slotted section in the centre of the tray to assist ashing.
PostPosted: Mon May 07, 2018 12:55 pm
My front ashtray also uses a wire for the hinge and spring effect is 2 tangs on the lid that rub along the fluted section. My issue is that the top has never sat flush with the vinyl at the windscreen side. The cabin side has a clip that holds it down.
Am I alone with this "feature"?
1970 Mk2 Cooper S
Users browsing this forum: No registered users and 122 guests
