It is currently Sat Jun 21, 2025 9:50 pm
 Post subject: Valve seals
PostPosted: Mon Nov 20, 2017 10:47 am
Can anyone tell me if these seals will fit under AEA-525 valve springs?
https://minikingdomonline.com.au/wp-con ... DU4905.jpg
 Post subject: Re: Valve seals
PostPosted: Mon Nov 20, 2017 11:33 am
yep
PostPosted: Mon Nov 20, 2017 12:48 pm
Thank you.
PostPosted: Tue Nov 21, 2017 9:28 pm
simon k wrote:
yep
I agree.
But watch the height of the guides. If much more than 1.5mm above the top of the head, and you are running 1.5 rockers and a big cam, they can get hit by the valve caps and the little springs come off. As I found on one build.
Last edited by drmini in aust on Fri Nov 24, 2017 2:26 pm, edited 1 time in total.
PostPosted: Thu Nov 23, 2017 11:40 am
Planning on std rockers and 266 cam.
