It is currently Wed Jun 25, 2025 12:19 pm
Post new topic Reply to topic  [ 235 posts ]  Go to page Previous  1 ... 12, 13, 14, 15, 16  Next
PostPosted: Sat Oct 07, 2017 7:56 am
timmy201 wrote:
There is a similar unit here, it has load based tuning like the Aldon unit
https://www.cbperformance.com/product-p/2013.htm
Looks like it might work.. VW owners over there don't buy crap that doesn't work
So they must have got the car for free?
PostPosted: Sat Oct 07, 2017 12:15 pm
Be nice, I was a VW and Formula Vee mechanic in a previous life. ;) Loooong time ago.
I still wouldn't mind a Manx buggy. 8)
PostPosted: Sat Oct 07, 2017 4:58 pm
mmmm, Manx. Now theres a way to make a VW into a great car. I've had three.......all gone now. :cry: :cry:
PostPosted: Sun Oct 08, 2017 7:09 pm
Hi Kevin how much is to much crank end play in air cooled combie engine. Helping a buddy of mine tidy up his kombi van. Ta Bernard
Sent from my GT-I9505 using Tapatalk
PostPosted: Sun Oct 08, 2017 9:34 pm
Sorry Bernard it's been too long... 1971? Not touched one since.
My memory now ain't what it was. I do remember the shims.
This may help you. :wink:
http://shoptalkforums.com/viewtopic.php?t=137434
PostPosted: Sun Oct 29, 2017 5:17 pm
Something strange happened today
I fitted new spark plugs as the engine was breaking down under load but otherwise running good
I also degreased the engine to remove a lot of road grime
Anyway went for a drive this afternoon to see how it went
Well it went OK for about 10kms then i lost power
The exhaust note changed as well
So i pulled over and had a look and didn't see anything wrong so i hopped back in and it drove fine again
For about 500 metres then it lost power and ran like the timing was retarded
Turned around and limped home only to get like 1 km from home and it ran fine again
Had a look at the dist, leads, wires, coil, etc and it seemed to be running like normal
Question is---- What happened to make it run like this
It has the accuspark module fitted
Did someone say it has a limp home mode if something goes wrong
Seems strange it was OK after the degrease then it played up then it came good
1970 MK2 Cooper S
PostPosted: Sun Oct 29, 2017 5:49 pm
My bet is you got moisture in the dizzy cap. Made it crossfire, then eventually it got hot enough to evaporate the moisture drops.
I have had it happen. I now spray WD-40 inside the cap every 6 months.
PostPosted: Tue Nov 28, 2017 9:37 pm
Ok the blackbox/accuspark has to go it really is rubbish. driven me nuts for way to long. it works then gremlins enter it then it works then it causes pinging then its fine, then it only starts when you turn the key back from start. arhhhhhhhh
There is a reason they discontinued it.
so the question is Scorcher or 123 with bluetooth ?
1968 Morris Mini Cooper S
PostPosted: Wed Nov 29, 2017 6:02 am
We are going to use this one on my son's 1300 clubby-
Made in USA not China. ;)
PostPosted: Wed Nov 29, 2017 6:23 am
Online
Mine has been great recently after I've upgraded the wiring to the front end of the car. Can you check how many volts you're getting at the coil while cranking? If the unit is not getting enough power it will give those starting symptoms
What type of ignition curve did you go with?
PostPosted: Wed Nov 29, 2017 9:18 am
I don't know why you lot persevere with distributors at all....
PostPosted: Wed Nov 29, 2017 10:13 am
What do we use instead?
PostPosted: Wed Nov 29, 2017 10:42 am
Speaking as one of "you lot", I removed the distributor once and the car wouldn't start, so I put it back in and the car ran beautifully. May have been the plug leads swinging free in the breeze that was the problem. :shock:
But seriously Simon, I guess everyone has their own objective with their car. As I work to get mine back :) on the road I am aiming to have absolutely as many things as possible original. I'm assured by the experienced guy doing the mechanicals that a properly serviced and adjusted 29D4 with good points, condenser, coil, leads and plugs will work just fine for my purposes, so that's the plan at this stage.
However I fully understand those who aren't constrained by originality taking a different approach for performance or reliability or whatever reasons.
PostPosted: Wed Nov 29, 2017 11:01 am
Unless you have a “lemon” unit I agree with Tim. It could be not getting enough volts. I have a CD player in my mini and it would sound terrible, distorted. I thought the speakers were blown. Turned out the car battery was dying and when CD got low voltage when stopped or idle it sounded terrible.
My black box has been fantastic, and for me the best part is looking in the engine bay it all looks all totally standard.
PostPosted: Wed Nov 29, 2017 11:13 am
Online
Megajolt is an alternative - trigger wheel, sensor, ecu and a coil pack
E.g.
http://www.trigger-wheels.com/store/con ... k/p98.html
Users browsing this forum: timmy201 and 98 guests
