It is currently Wed Jun 25, 2025 8:36 am
Post new topic Reply to topic  [ 235 posts ]  Go to page Previous  1 ... 11, 12, 13, 14, 15, 16  Next
PostPosted: Sat Sep 16, 2017 8:30 pm
Cheers Kev,
I've got the battery on the trickle charger this afternoon, I'll see how it is in the morning. I checked the battery spec on the current battery, it's a 43 with only 260CCA. Might have to consider upgrading mine!
PostPosted: Thu Oct 05, 2017 6:38 pm
Have many updates of the box come out?
I'm in the middle of building a custom front loom and want to purchase to incorporate now, but my car is unlikely to be on the road for 1-2 years.
Worth risking an updated version coming out?
PostPosted: Thu Oct 05, 2017 7:30 pm
Online
They are no longer available new. Accuspark appear to have pulled it.
No word on any updates.
Aldon released a similar box called an Aldon Amethyst. Google seems to show it gave problems and is now NLA also.
PostPosted: Thu Oct 05, 2017 7:58 pm
There is a similar unit here, it has load based tuning like the Aldon unit
https://www.cbperformance.com/product-p/2013.htm
PostPosted: Thu Oct 05, 2017 8:04 pm
Its a shame, for the want of a software update.
My one is still rock solid, pushes a high energy coil and a large plug gap.
I have a spare unit new, but it needs a fresh copy of Windows Vista to operate the software...
PostPosted: Thu Oct 05, 2017 8:25 pm
Online
Looks like it might work.. VW owners over there don't buy crap that doesn't.
(Edit) CB Performance makes a whole heap of air cooled VW go faster stuff.
PostPosted: Thu Oct 05, 2017 9:47 pm
I just checked the Aldon website and there is a new 2017 version available and in stock (or so they say) - it looks like it went out of stock around May and back in stock in Sept but that may have been waiting for the updated version?
. I got one a while back but have not run it properly yet - would be interested in what the reported problems are as I did a search and found a few comments but as usual there were opposite and contradictory opinions in the same threads?
The same comments seems to go for the black box.
Rod
PostPosted: Fri Oct 06, 2017 7:39 am
I ended up with a Swiftune CSI dizzy after changing 4 dead Stealth boxes over and over - 16 advance curves available, and no voltage/windows update/any issues to speak of.
Couldn't be happier 8)
PostPosted: Fri Oct 06, 2017 9:01 am
Online
There is now a 123 Bluetooth, if you have $500+ handy...
https://www.123ignitionshop.com/gb/tune ... tooth.html
PostPosted: Fri Oct 06, 2017 11:03 am
$660 from 123 Ignition australia.
Didn't they have a programable one you plugged into as well?
Rod
PostPosted: Fri Oct 06, 2017 11:12 am
Here is the USB version. Still pretty pricey.
https://www.123ignitionshop.com/gb/asto ... e4rvg.html
The nice thing about the Accuspark/CB Performance/Aldon Amethyst box is that you can install it to your original distributor and hide it away. If I was going all out for performance I'd also think about a megajolt kit.
http://www.trigger-wheels.com/store/con ... k/p98.html
PostPosted: Fri Oct 06, 2017 1:54 pm
Online
Rod
Apart from the USB version,
The original 123 had 16 advance curves that you could select from, after removing a plug underneath. However if none suited your build there was no curve adjustment.
PostPosted: Fri Oct 06, 2017 8:13 pm
How useful is the dwell function on the stealth? A must have, or just used because it's included?
Leaning towards the CB unit, but missing the dwell function
Sent from my HTC_PN071 using Tapatalk
PostPosted: Fri Oct 06, 2017 8:43 pm
There is a video on the dwell adjustment here.
https://youtu.be/W-C7gA2xW3o
PostPosted: Fri Oct 06, 2017 8:45 pm
Online
I think the CB one adjusts the dwell automatically. You don't need a lot of dwell at low speed. And on the stealth you have to ensure that you don't set it too high as advance increases. Dwell + advance must total less than 90°.
Cost of the CB one landed here is about A$333. May use one for my son's 1300 build.
Users browsing this forum: drmini in aust, ken@miniauto and 94 guests
