It is currently Sat Jul 19, 2025 3:21 am
 Post subject: PBR Brake Booster
PostPosted: Thu Oct 05, 2017 2:02 pm
This doesn't look right.
Please advise what needs to be rectified.
 Post subject: Re: PBR Brake Booster
PostPosted: Thu Oct 05, 2017 2:10 pm
The master cylinder bit needs to be flipped 180° on the servo canister if going into an S or roundnose. However if fitting it to a clubby it is better mounted pointing backwards, as assembled.
PostPosted: Thu Oct 05, 2017 3:16 pm
If you want to put in a 69mk2 S its incorrect should be the mk1 lockheed
PostPosted: Thu Oct 05, 2017 3:31 pm
Apparently changed at YG2S4 1614 in Mar 1970. Lots of cars with the wrong one.
PostPosted: Thu Oct 05, 2017 7:13 pm
Supposed to be gold and not silver and body isnt black
