It is currently Wed Jul 16, 2025 8:38 am
 Post subject: What goes here?
PostPosted: Sun Sep 24, 2017 5:55 pm
Hi All
There is a threaded hole in my pudding stirrer gearbox (next to the block the gear lever goes into)
What is meant to go there?
I'm assuming it's an exhaust mount of some sort but what sort of fitting screws into the hole?.
Here's the view from the underside of the car (to the right of the exhaust pipe);
and here it is from the top;
Dave
"64 Smooth Roof Van (Colin)
 Post subject: Re: What goes here?
PostPosted: Sun Sep 24, 2017 6:54 pm
Winnabey will know. Parts expert extraordinaire.
PostPosted: Sun Sep 24, 2017 7:15 pm
Proper 850 exhaust pipe has a bracket welded on it to align with that lug. Exhaust pipe is used to help cope with torque reaction.
Without the bracket and a bolt you will break the pipe's flange where it attaches to the manifold.
PostPosted: Sun Sep 24, 2017 7:46 pm
You can see it on the diagram here
http://www.somerfordmini.co.uk/eshop/in ... age&id=178
PostPosted: Sun Sep 24, 2017 10:09 pm
Thanks all
I may need to weld a bracket onto the exhaust pipe and bolt the gearbox to it!!
Dave
PostPosted: Tue Sep 26, 2017 2:11 pm
850's had a gearbox steady that no other models had.
Could have been the mounting point for this?
PostPosted: Tue Sep 26, 2017 3:58 pm
No. It's for exhaust. I had an 850 back in early 60s, the only extra steady was sold as an accessory, that bolted to the gearbox underneath and ran back to the subframe floor mounting bolt.
PostPosted: Tue Sep 26, 2017 4:40 pm
The exhaust pipe came with the support bracket already welded to it. You can see it in the following diagram.
PostPosted: Tue Sep 26, 2017 5:02 pm
You can buy extra steady / stabilisers if using a rod change or magic wand:
http://www.minispares.com/product/Class ... K1000.aspx
Lower LH
http://www.minispares.com/product/Class ... SK001.aspx
Lower RH
http://www.minispares.com/product/Class ... /MSSK.aspx
PostPosted: Tue Sep 26, 2017 10:15 pm
A lower steady would also be handy as the gearbox does tend to move around a fair bit!!!
PostPosted: Tue Sep 26, 2017 10:19 pm
It will move around far less after you bolt the exhaust bracket on. :wink:
PostPosted: Wed Sep 27, 2017 7:32 am
Thanks Doc-I'll weld a bracket on this weekend :D
PostPosted: Wed Sep 27, 2017 8:52 am
The proper bracket is wrapped partly around the pipe for strength. Don't just weld a flat piece against it, that will crack the pipe.
Put a fold in it and bend it over the pipe a bit.
PostPosted: Wed Sep 27, 2017 12:04 pm
Hi Doc
I was also thinking about something like this-either welded on or just clamped tight
http://www.britcycle.com/Products/images/743001.jpg
Dave
PostPosted: Wed Sep 27, 2017 12:17 pm
Hi Doc
Dave
A bracket like that going around the pipe seems like a good idea. You should be able to get one locally or even make one from steel bar.
MKO have original BMC NOS versions if that's of interest.
https://minikingdomonline.com.au/produc ... o-gearbox/
I'll post the BMC Australia engineering drawing for exhaust pipe and the original bracket in a moment. Just need to make some adjustments.
