It is currently Sat Jul 19, 2025 3:43 am
 Post subject: Panel shape
PostPosted: Mon Sep 18, 2017 10:33 am
Hi, Can anybody tell me if the panel between the rear of the door and the rear wheel arch is flat or has a slight curve? If curve where does the curve start?
Mk 1 Cooper S 1965
If you could erase all your mistakes of the past
You would also erase the wisdom of your present
Remember the lesson not the disappointment.
 Post subject: Re: Panel shape
PostPosted: Mon Sep 18, 2017 10:46 am
Does any of this cover what you are asking about?
viewtopic.php?f=2&t=92470&hilit=rear+panel+curve
PostPosted: Mon Sep 18, 2017 11:04 am
Thank you .That answers my question perfectly. Mine has a slight curve on the drivers side exactly as in the picture, but on the passengers side I had to remove a lot of bog from previous accident damage repair. I wasn't sure whether to reproduce the curve or make it flat, I don't want to stretch the metal out if not necessary.
Mk 1 Cooper S 1965
