It is currently Sat Jul 19, 2025 3:31 am
 Post subject: Reading these plugs
PostPosted: Tue Sep 05, 2017 9:00 pm
With thanks and acknowledgement to those that contributed on the FB site, I thought I would also ask those gathered here - any ideas on why these plugs look the way they do? Single carb car - compression test gave 160psi on 3 cyls and 165psi on 1 cyl. Leakdown test provided 4-5% on 3 cyls and 7% on one cylinder.
Thanks.
'68 Deluxe w/Metro engine
 Post subject: Re: Reading these plugs
PostPosted: Tue Sep 05, 2017 9:06 pm
Have you checked for inlet manifold leaks ?
Cyl 3 & 4 leaner than 1 & 2
just an option to look at .
PostPosted: Tue Sep 05, 2017 9:15 pm
Thanks Slacko. That came up on the FB post. Hard to imagine where a leak could exist, but I may just have to pull the manifold and check for flatness. I guess there is a very slight chance that the water cooling passage has a corroded through, but it hasn't had water in it since I've owned the engine. And of course the manifold gasket itself... Cheers.
PostPosted: Tue Sep 05, 2017 9:23 pm
easy to check
with the engine running pour water or wd40 over the inlet branch where it bolts to the head and if you have a leak the engine tone will change , water will probably kill it and wd40 may make it speed up , if so a new gasket could fix this
PostPosted: Wed Sep 06, 2017 5:27 pm
Matt,
I've had cases in the past where the inlet manifold does not sit square or flat on the head due to extractors. i.e. not enough clearance.
Just a thought.
Pete
PostPosted: Wed Sep 06, 2017 6:34 pm
Have you discounted weak spark. Bad HT leads or spark tracking at the cap.
PostPosted: Wed Sep 06, 2017 8:57 pm
gtogreen1969 - I haven't, but it is running quite well. Could I have weak spark to discolour the plugs yet it runs ok?
I'm assuming on this suggestion we would be looking at weak spark on 1&2? (ie tracking between 1&2?)
Thanks for the suggestion.
PostPosted: Wed Sep 06, 2017 9:10 pm
Chuck an ohmmeter on the leads. Anything around 2k ohms is good.
Users browsing this forum: No registered users and 118 guests
