It is currently Sat Jul 19, 2025 3:27 am
 Post subject: Cooper S Engine colour
PostPosted: Sun Sep 03, 2017 7:55 am
Hi all
The time has come to get my mark 1 into the shed and start the resto, I will have lots of questions coming no doubt
Motor and gearbox is coming out for rebuild and repaint .
Was there an original colour used on the motor or were they all different
Thanks in advance
PostPosted: Sun Sep 03, 2017 8:37 am
The Australian Mk 1 engine & gearbox were painted "Cooper S Metallic Green" over the original dark green UK paint, The paint code is CP 8689.
PostPosted: Sun Sep 03, 2017 2:46 pm
500ml tins are available from Mini Kingdom. It took the full 500ml to paint mine with three good coats.
Make sure you clean the engine thoroughly before painting otherwise the paint will not stick - I washed mine four times with Prepsol, prior to that the engine had been cleaned by the engine rebuilder.
John Sneddon
0408 431 807
1963 Morris Cooper
1965 Morris 850
1968 Morris Cooper S
PostPosted: Sun Sep 03, 2017 4:20 pm
I only ever paint my engines with cheap rattle cans in whatever colour I feel like on the day, but I always give them a coat of etch primer first - never had it flake off, so that's my tip
PostPosted: Sun Sep 03, 2017 8:44 pm
What if you are painting over old paint? What's the best prep?
Cooper S Mk2
Cooper S Mk1
Users browsing this forum: No registered users and 123 guests
