It is currently Sat Jul 19, 2025 3:41 am
 Post subject: Ball and cups
PostPosted: Mon Aug 28, 2017 9:04 pm
Hi all what's the best way to replace the ball and cups in the suspension? How long does the job normally take?
 Post subject: Re: Ball and cups
PostPosted: Mon Aug 28, 2017 10:04 pm
Hydro = Drop the pressure. Dry = Take out the top arm or cut the trumpet and fit HiLos after your done.
Couple of hours to a couple of days. Depending on what else breaks.
PostPosted: Tue Aug 29, 2017 6:50 am
I don't want to dampen your enthusiasm but unless you really do know what you're doing or you can get someone who does to help/show you, it's not what I'd put in the 'handyman' job catagory. Trumpets can split, shatter trying to get old ones out.
PostPosted: Tue Aug 29, 2017 6:52 am
spring compressor for dry suspension
PostPosted: Tue Aug 29, 2017 8:51 pm
Yep. My favoured tools for removing the original trumpets are a BFH and a hatchet.
PostPosted: Wed Aug 30, 2017 6:43 am
Knuckle joints and hill's should come as a kit. :-):
