It is currently Sat Jul 19, 2025 7:59 am
 Post subject: Which boss?
PostPosted: Fri Aug 25, 2017 2:54 pm
Just bought a new 'RPM' steering wheel to replace my slippery Luisi wheel, however the boss doesn't match up. New wheel is 330mm with 90mm dish, internal ring is 55mm, space between screws is 35mm, 6 screws in total. Have been told I might need to order one to be made from autotechnica.
What are my options?
Thanks.
 Post subject: Re: Which boss?
PostPosted: Fri Aug 25, 2017 3:18 pm
Steering wheels are normally sized by the Pitch Circle Diameter (PCD), which is the measurement between opposite holes. Do you know that measurement? I'm guessing 70mm
PostPosted: Fri Aug 25, 2017 3:56 pm
Yes. PCD is 70mm on new wheel.
PostPosted: Fri Aug 25, 2017 4:11 pm
From what limited info I can find on Luisi wheels they seem to be 74mm pcd.
There are many 70mm mini boss kits on the net, SAAS, Autotecnica, etc
There are even some that have 70mm and 74mm so you can still use your old wheel.
E.g.
http://www.ebay.com.au/itm/STEERING-WHE ... Swal5YETsZ
http://www.ebay.com.au/itm/MINI-MOKE-MU ... SwNyFWc1ti
http://www.ebay.com.au/itm/Morris-1100- ... SwX9FZE~V0
http://www.ebay.com.au/itm/MINI-1967-19 ... SwH35ZmkkQ
PostPosted: Fri Aug 25, 2017 4:16 pm
Thanks for that. Will probably order a universal boss from minisport. Option of using both wheels is a great idea.
Users browsing this forum: No registered users and 69 guests
