It is currently Sat Jul 19, 2025 7:32 am
Post new topic Reply to topic  [ 52 posts ]  Go to page Previous  1, 2, 3, 4  Next
 Post subject: Re: Original underlay
PostPosted: Mon Aug 07, 2017 7:17 pm
Thanks ausdino :)
There are some items I'm unsure of in the photo so makes it interesting and research needed.
Would you be able to post a photo of the firewall sound proofing for a closer look. Would just like to check some detail. Cheers
PostPosted: Mon Aug 07, 2017 9:01 pm
No problem, will do asap for you. Just have to move things again.
PostPosted: Mon Aug 07, 2017 11:52 pm
Any others you need, just ask. I'll pack them away again in a week or so.
PostPosted: Tue Aug 08, 2017 1:22 pm
You may have considered this already. when i got my MkII S, there were four pieces of underlay in the boot, cushioning the fuel tanks - a strip under each tank and a patch about half the size of a cigarette pack on each of the mounting points for the tank straps where they joined the back of the seat. NB - those tank mounting straps also had a thin layer of cork on the inside. Cheers, P
Min - 1970 MkII S, 119hp Dave Anton 1380, SH Engineering belt drive, 1.5 rollers, 123Tune ignition, 48 DCO SP Weber, HP Headers, MSD, Maniflow ex. Swiftune SC/CR 3.7 + ATB, all KAD front, antiroll bars and gas shocks, 6 inch Minilites with Dunlop Sports
PostPosted: Tue Aug 08, 2017 2:16 pm
Correct :) and Thank you. I managed to complete those when I refitted the fuel tanks.
PostPosted: Tue Aug 08, 2017 8:15 pm
Thank you once again ausdino :)
Could you please take a photo of the under bonnet sound proofing/engine bay firewall which has has the vinyl on one side.Could I please have a photo of each side for detail.
It is very much appreciated.
Cheers.
PostPosted: Wed Aug 09, 2017 11:44 pm
I don't know the originality of this. It came with the car and hasn't been unpacked for 33years......
and texture
PostPosted: Fri Aug 11, 2017 6:06 am
Looks right to me
Simonw
Brisbane QLD
- 1969 Mini K
PostPosted: Fri Aug 11, 2017 7:56 pm
Thank you ausdino
It looks to be original to me and I'm not sure but there appears to be a change at some point with the grain in the vinyl around 1969/1970.
What is left of my original item is the fine grain vinyl.
Thank you for all your time and help.
PostPosted: Sat Aug 19, 2017 9:00 am
My S has had this aluminium bituminous material adhered to the body under carpet during it's last restoration. It is only around 3-4 years old and it's still possible to remove it with some patience. I've finished removing the terrible stuff behind the dash (once the aluminium tears, it's extremely sharp). I didn't notice till I'd finished a section, my hands were cut to bits.. Next I'll be removing it from the floor and firewall.
My question(s) are;
1. What I should be putting back there to be more correct. knowing I don't have the original material.
2. Did Mini's have anything on the floor between the insulation and the metal.
3. Was the insulation fixed to the metal work with a type of contact adhesive?
4. Was the carpet glued to the insulation?
Mat
1970 Mk2 Cooper S
PostPosted: Sat Aug 19, 2017 9:16 am
Mat,
The original underlay in my Mk2 Cooper 'S' was loose fitting under the carpet with no adhesive.
PostPosted: Sat Aug 19, 2017 11:41 am
The underlay on the inner firewall on my '69 Mk2 was glued and even some between the pedal box and bulkhead.
PostPosted: Sat Aug 19, 2017 12:03 pm
My question(s) are;
Mat
Since it's out of sight you could use any of the current felt type underlay. The original stuff had some nasty ingredients apparently, although I've never tasted it.
No. The insulation sat on the painted floor surface with the carpet on top. The whole lot was held in place by the press-studs in the carpet.
No, as above.
No, except as below.
As mentioned earlier by Stibbsy, on the inner firewall (behind the pedals and heater) that piece of carpet is glued to the underlay which is then glued to the firewall. There is no underlay on the inner guards - the carpet is simply glued to the painted metal.
PostPosted: Sat Aug 19, 2017 1:16 pm
and texture
That's interesting, I thought mine had been butchered because of the little triangle cut out, I guess not. Thing is, I can't work out what the cut-outs are actually meant to be accomodating?
Mine:
PostPosted: Sat Aug 19, 2017 2:36 pm
A couple of those pictures show the insulation upside down. The triangular cutout is for the wiper motor and the rectangular one for the master cylinders.
Users browsing this forum: No registered users and 72 guests
