It is currently Sat Jul 19, 2025 7:48 am
PostPosted: Sat Aug 12, 2017 9:06 pm
hello there owners of Rover Minis - I'd like to know what angle your steering column pinch bolt is at when the front wheels are pointing straight ahead
Here's a snip from the Rover workshop manual, it shows the bolt at ~45° from horizontal. Is that the way it looks on your car?
I'd appreciate it if someone could take a look for me
PostPosted: Sat Aug 12, 2017 11:27 pm
How do we know the steering wheel is straight in that photo?
Also, they could be in any position - the shaft is free to be installed at any rotation angle till the steering wheel goes in.
PostPosted: Sun Aug 13, 2017 10:20 am
https://www.youtube.com/watch?v=2CkmyyPiBD0 :lol: :lol: :lol:
PostPosted: Sun Aug 13, 2017 1:19 pm
it's a simple question Aaron...
PostPosted: Sun Aug 13, 2017 5:57 pm
Simon If I remember I will grab you a pic tomorrow of how mine is.
PostPosted: Sun Aug 13, 2017 6:32 pm
simon k wrote:
Fine, here's the simple answer then:
My was not that way originally.
PostPosted: Sun Aug 13, 2017 7:26 pm
Sime, if all else fails...I will take a drive out in the country and get you a picture of one :-)
PostPosted: Sun Aug 13, 2017 7:54 pm
Try a PM to Brian Kozan - viewtopic.php?f=8&t=95869
PostPosted: Sun Aug 13, 2017 9:03 pm
I might be wrong I've not seen a rover one but wouldn't you have to align the indicator cancelling feature correctly and that decides where it sits? Other than that unless the splines into the rack are not the same all the way round I can't see it matters, I don't have a rover though...
Roads need more corners
PostPosted: Sun Aug 13, 2017 9:06 pm
Ive done racks on 2 rovers now, both times the pinchbolt was horizontal. They were both original racks i took out, too.
PostPosted: Sun Aug 13, 2017 9:20 pm
thanks Brenton - a photo isn't really necessary, but appreciated - a rough angle will do
I gather Rovers don't have the same kind of self cancelling as our Aussie cars - there's some kind of peg on the base of the steering wheel which goes into a mechanism on the switch, or something
thanks Jim - did the pinch bolt slot go all the way around the shaft, or just though one point?
PostPosted: Sun Aug 13, 2017 9:32 pm
The slot was only across one side of the pinion.
PostPosted: Sun Aug 13, 2017 9:48 pm
that's what I was after, thanks very much
PostPosted: Mon Aug 14, 2017 8:51 am
Mine is horizontal (east west) under the column
PostPosted: Mon Aug 14, 2017 12:16 pm
beautiful
