It is currently Tue Jul 15, 2025 3:04 pm
 Post subject: Re: Worn inner pot joint
PostPosted: Wed Aug 09, 2017 2:18 pm
Whooo. I like the answers. Yes. Will swap the cages. The big cage will be too big to fit in the small pot anyway. Thank you good people.
Ok. What about play in the diff output shaft... I can wiggle it. How much jiggly is too wiggly?
PostPosted: Wed Aug 09, 2017 3:03 pm
Output shafts can wiggle a bit without the pot joint on. But if you can rock the pot joint in the side cover the cover's bush is worn and this can give leaking seals.
To replace the bush it is pressed into the cover, then the cover chucked true in a lathe and the bush bored to fit. New bushes are around .010" undersize.
I give them .001" clearance on the pot joint. ie. make 1.251" diameter.
PostPosted: Sat Apr 07, 2018 9:23 pm
How is the old side cover bush removed?
PostPosted: Sun Apr 08, 2018 7:22 am
I cut with a hacksaw then push the 2 bits out.
I fit new ones carefully with the vice and a suitable socket.
PostPosted: Sun Apr 08, 2018 4:32 pm
Thanks drmini. I decided to make one hacksw cut where 22G421 bush joins and the tapped it out with a 5/8 W socket. Now I need to purchase new bushes and work out how to ream them to fit the drive shafts.
PostPosted: Mon Apr 09, 2018 7:08 am
They are press fitted to the cover then bored true in a lathe. If you ream them by hand you can get them crooked and they will bind on the drive flanges. PM sent.
