It is currently Fri Jun 20, 2025 11:15 pm
Post new topic Reply to topic  [ 274 posts ]  Go to page Previous  1 ... 15, 16, 17, 18, 19  Next
PostPosted: Mon Jul 24, 2017 8:17 pm
Is it possible for you to give a step by step on how to do those 15" rims?
Zulu...
1967 mini Cooper S
PostPosted: Tue Jul 25, 2017 12:08 pm
fuzzy-hair-man wrote:
Congratulations on the feature in Mini World Brad!
Thanks mate, it was a surprise but a good one when they asked to feature it.
I've currently got the gearbox out, going to fit an LSD and new clutch :D
1974 Moke - 998cc
PostPosted: Tue Jul 25, 2017 12:22 pm
I'm running 14x6 inch wheels, not 15's.
Wheels are 4x100 stud pattern. To do this I had the front wheel flanges and rear flanges/drums redrilled to a larger hole for thicker wheel studs @ 4x100. The new hole for the thicker wheel stud wipes out the old smaller 4x101.6 stud holes.
Tyres are 195/40/14 - rolling diameter is 511mm, as apposed to 505mm for 175/50/13. The extra rolling diameter isn't an issue, the same front guard cutting is needed, rear tubs are untouched.
1974 Moke - 998cc
PostPosted: Tue Jul 25, 2017 12:26 pm
That actually sounds pretty simple. Were there any things to be aware of? Tips and tricks?
Zulu...
1967 mini Cooper S
PostPosted: Thu Jul 27, 2017 4:42 pm
Did you get done at a drag racing shop? Do toe 14x6 affect your turning circle? Do they rub? The same front guard cutting as for 13's?
Zulu...
1967 mini Cooper S
PostPosted: Fri Jul 28, 2017 2:45 pm
I got the drilling done at a local engineering/metal fabricator shop.
Yes turning circle is not as good as it used to be but I've never needed to do a 3 point turn yet, still does a U turn on a 2 lane road no problem. They will rub on the inner wheel well if on full lock.... That has more to do with the offset of the wheels as I didn't want to fit large flares.
Yes same front guard trimming as the 13's.
1974 Moke - 998cc
PostPosted: Fri Jul 28, 2017 3:02 pm
Sorry, not sure who took these but I like them :D
1974 Moke - 998cc
PostPosted: Fri Jul 28, 2017 7:56 pm
They look awesome. I liked the first lot you had too. I wonder if with wider arches and a spacer if they wouldn't rub. But, being tight in like that looks awesome. Did you need to get an engineering report done?
Zulu...
1967 mini Cooper S
PostPosted: Mon Jul 31, 2017 1:38 pm
1974 Moke - 998cc
PostPosted: Tue Nov 26, 2019 9:47 am
Just a little update on my 993cc mini.
Took it to the Mighty Car Mods meet in Sydney on the weekend for some fun and the mini is offically a 14 second car. It now lives up to its original thread name :D It ran 4x 14.9 runs with the best being 14.90 at 93.9mph. It won 3 out of 5 races :shock:
Such a fun little car, drove the 3 hour round trip no issue at all.
Also I've now built a moke for summer. Only a 998 in this for now.
Sneak preview for the next mini project getting underway :D (11 secmini ?)
1974 Moke - 998cc
PostPosted: Tue Nov 26, 2019 8:22 pm
13secmini wrote:
Sneak preview for the next mini project getting underway :D (11 sec mini )
That's the B series CRV? You weren't tempted to use the K series?
Guessing awd n/a.
Roads need more corners
PostPosted: Wed Nov 27, 2019 8:09 am
Love your work Brad, excited to see/hear some updates and sneak previews of further work to come :-)
1972 Leyland Clubman, 4EFTE 1330cc Turbo, 220Hp on 17psi
(1/4 mile: 13.8s @108mph @168Hp)
PostPosted: Wed Nov 27, 2019 10:01 am
Guessing awd n/a.
Correct, B series AWD running gear to suit my B16A Turbo engine i have lying around :D
K series seem to be a great platform, but Aussie laws say i can only put a 1.6L turbo in a clubman unfortunately.
1974 Moke - 998cc
PostPosted: Wed Nov 27, 2019 10:03 am
Hey Ray, I will probably get a start on it over Xmas, will try to throw some updates on here when I can.
Have you still got the 4efte mini? hows it going after all these years?
1974 Moke - 998cc
PostPosted: Wed Nov 27, 2019 11:14 pm
13secmini wrote:
.... but Aussie laws say i can only put a 1.6L turbo in a clubman unfortunately.
Actually, that is just NSW rules really. Although it has ended up in the so-called 'national guidelines', they are just that - guidelines. So in SA at least, anything is possible with a proper engineers report.
Don't listen to what I am saying... just understand what I mean.
