It is currently Wed Jul 16, 2025 1:30 am
PostPosted: Tue Jul 18, 2017 4:43 pm
Hi all,
Wondering if anyone can help. I have a 2/70 MK2 S in many pieces.
Brake and clutch master cylinders both measure 0.70. Both are plastic resevioir. One is alloy marked Lockheed, other is Cast iron marked Girlock.
Would either be the correct brake master cylinder ?
Any opinions on best option for clutch master ? Bore and sleeve one of the existing, try to acquire a correct 0.75, try and exchange somewhere for a refurbed clutch mc ?
Thanks in advance
Andrew
PostPosted: Tue Jul 18, 2017 4:53 pm
Minikingdom has them listed as exchange units:
https://minikingdomonline.com.au/produc ... -exchange/
Brake
https://minikingdomonline.com.au/produc ... ange-copy/
don't know the measurements, but my 7/70 car has 2 x cast iron with Lockheed reservoirs
PostPosted: Tue Jul 18, 2017 5:43 pm
Atay wrote:
Hi all,
Thanks in advance
Andrew
Same configuration as my 3/70 Mk2 S which is also in many many bits. Sorry to be of no help, but will follow this thread.
PostPosted: Tue Jul 18, 2017 6:17 pm
I sent my MCs to a brake shop also booster stainless liners etc cost $700. CS 4, 1970.Soon to be on road costing me big dollars. Full resto P7676
PostPosted: Tue Jul 18, 2017 8:29 pm
My 8/70 S has cast iron Girlock brake and clutch M/cylinders (plastic reservoir). Brake M/C = 0.70"; clutch M/C=0.75" Mine are probably original and resleeved.
There were alloy bodied M/cylinders but I don't know what they were meant for.
PostPosted: Tue Jul 18, 2017 8:44 pm
Thanks all for your responses. Very helpful. Cast iron it is. I will see if I can exchange the alloy .70 MC on a .75 cast one.
PostPosted: Wed Jul 19, 2017 9:15 am
they came after the cast iron version - clubbies
PostPosted: Wed Jul 19, 2017 7:17 pm
Just clean them up and get them stainless steel sleeved .
PostPosted: Wed Jul 19, 2017 9:16 pm
From what I have read, clutch should be .75 and both MC's are .70
Am I right in thinking ditch one of the .70's for a .75 ?
PostPosted: Thu Jul 20, 2017 4:11 am
You don't have to ditch one , just ask them to sleeve to .75 .
PostPosted: Thu Jul 20, 2017 7:08 am
Gotcha. Thank you
PostPosted: Thu Jul 20, 2017 11:17 am
You would then have to get the internals to suit then. Are they readily available as spare parts with the 0.75 seal kit?
PostPosted: Thu Jul 20, 2017 7:39 pm
The Brake Specialist where you get it sleeved should be able to supply the cups for it .I'm not sure who does the sleeving in the Sydney area , someone on here may know .
PostPosted: Thu Jul 20, 2017 9:18 pm
Warringah Brake and Clutch at Brookvale can get them resleeved/reconditioned.
Usually a couple of days as they send them away
They did all my brake cylinders and pipes and hoses about 5 years ago
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
