It is currently Fri Jul 18, 2025 3:26 am
 Post subject: Rocker Cover decals
PostPosted: Mon May 29, 2017 7:00 pm
Hi guys for a 1968 Cooper S, what were the decals that went on it.. I presume one is the Hot run tested. and was the Morris badge a sticker or metal?
Cheers Brett
 Post subject: Re: Rocker Cover decals
PostPosted: Mon May 29, 2017 7:42 pm
Morris sticker at the front. Hot run sticker at the back.
PostPosted: Mon May 29, 2017 7:54 pm
Thanks
PostPosted: Mon May 29, 2017 8:15 pm
The 65-66 cars had the Morris plate at the front and the patent plate at the rear. 66-69 had the 2 stickers as mentioned above. 1970 went to the Hot run tested only at the front. This is only from looking through period photos and low owner unrestored cars. Maybe someone with John Sneddons book could confirm this or get the change over more accurate.
