It is currently Thu Jul 17, 2025 12:35 pm
 Post subject: cracks in rotor
PostPosted: Thu May 18, 2017 9:40 pm
Hi All
I purchased the Tarox 6pot brake setup about 5 years ago and have come across some cracks appearing on the edge of the rotors, have you seen this before and is it a major problem? Doesn't look good to me, I have emailed Tarox, no reply as yet.
 Post subject: Re: cracks in rotor
PostPosted: Thu May 18, 2017 10:22 pm
It sure is a major problem and i would be replacing before driving the car. When it come to safety your brake system is a major safety component and i wouldn't want to be in a car when a rotor falls apart and fails due to cracks. Ive never heard it happening to anyone but I've definitely heard and seen cracks in rotors especially cross drilled rotors cracking from the holes to outer edge due to not enough material. Constant heat and cooling of the rotor and poor quality of material used causes this.
Are your rotors slotted slots if that makes sense? ( long curving slots that go straight though the casting to the hollow ribbed centre)
PostPosted: Thu May 18, 2017 10:49 pm
Bin it! :idea:
PostPosted: Fri May 19, 2017 7:59 am
Holy crap!
Sent from my SM-G900I using Tapatalk
PostPosted: Fri May 19, 2017 8:28 am
Whilst not great, also not terribly unusual - you should see the disc rotors in Group N cars :lol:
If in doubt, replace!
PostPosted: Fri May 19, 2017 1:33 pm
That's a bit of a worry. Any idea what discs the kit uses, are they made especially for tarox or are they standard on something else?
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
PostPosted: Fri May 19, 2017 1:45 pm
I had 2 cracks like that on a Cooper S rotor once. It was an RDA one (Chinese). Track days at Wakefield Park did it.
PostPosted: Fri May 19, 2017 5:12 pm
Did you mean Tarax? Rotors made from recycled cans...might be a little soft :!: :lol:
https://www.youtube.com/watch?v=yJQJp4DPBl4
[joking, OK? http://en.tarox.com/]
PostPosted: Fri May 26, 2017 7:18 pm
For peace of mind, I would replace it.
PostPosted: Fri May 26, 2017 7:58 pm
Definitely need replacing.
Since they charge a premium for a premium product and they're listed as 'ideal for track use', I'd be hoping for a replacement. Any brake component that starts cracking like that either hasn't been properly manufactured, or it's not up to the standard that they claim.
PostPosted: Mon May 29, 2017 7:39 pm
For peace of mind and safety reasons, I would replace them asap.
Users browsing this forum: Bing [Bot] and 87 guests
