It is currently Tue Jul 15, 2025 9:08 am
 Post subject: unusual wear on clutch
PostPosted: Thu May 18, 2017 9:45 pm
Hey All
I purchased the attached kit 3 years ago and installed it in a B16A cable box, has been fine with only very slight judder on occasions, the gearbox requires a rebuild that's the reason why I have found this - the uneven wear due to heat, assuming it is due to a faulty pressure plate? You can see slight scratching on the clutch plate on every second rivet and the faces of the other two are self explanatory.
PostPosted: Fri May 19, 2017 6:35 am
Looks like slipping / excessive hard starts to me.
PostPosted: Fri May 19, 2017 9:50 am
engine mounts not stiff enough?
ask on a honda forum, maybe it's a normal thing
PostPosted: Sat May 20, 2017 11:29 am
My initial thought was clutch cover not installed evenly because of how the hot spots on the flywheel are but there other things that can give those symptoms too. Maybe while it's out assemble it while it's on the bench & see how the diaphragm fingers sit & if they are worn unevenly & have a look at the throw out bearing too for wear etc.
Now is the easiest time to replace it :wink:
In the 3 years that you have had it, how many klm do you think you have travelled?
Brad
During the day I work on English designed cars & on my own time I work on English designed cars....
PostPosted: Sat May 20, 2017 12:25 pm
Cheers for the feedback
Not many hard starts and I didn't slip it too often.
Engine mounts are rock solid, I have posted on 16vminiclub too
Bugger all kms - 2K/3K
