It is currently Wed Jun 25, 2025 8:13 pm
Post new topic Reply to topic  [ 235 posts ]  Go to page Previous  1 ... 10, 11, 12, 13, 14, 15, 16  Next
PostPosted: Tue Jan 17, 2017 12:10 pm
Online
At the moment I get nothing on the gauge. From memory I connected it to the green wire from the blackbox
PostPosted: Tue Jan 17, 2017 2:59 pm
Mine is on neg terminal of coil. It's a near new AutoGage one, made by Autometer.
PostPosted: Thu Mar 23, 2017 3:00 pm
So what map is everyone running now ?
Sent from my SM-G935F using Tapatalk
PostPosted: Thu May 11, 2017 2:29 pm
Are these still available new? Are they compatible with the latest Windows? My old PC in the shed just died so I don't have access to an XP machine any more.
M
PostPosted: Thu May 11, 2017 2:39 pm
Online
I got mine from Convertible Mini last year, I think he was getting them direct from the supplier?
PostPosted: Thu May 11, 2017 7:47 pm
I purchased mine from Convertible Mini late last year.
Found it did not work with the late A+ electronic distributor - the one with the electronic box mounted on the outside of the distributor.
So I have just fitted an early A+ distributor, converted it to electronic with a kit from MiniKingdomOnLine, and it works a treat. Notable improvement in low down power which I put down to earlier advance.
I am yet to try different curves, but I will try something similar to the Aldon yellow.
I did try Tony Convertable Mini, but it sounds like he is out of action - hope he is OK.
PostPosted: Thu May 11, 2017 8:18 pm
Thanks for the info. I do have a late A+ electronic dizzy. Since I already have Ben's excellent kit with the trigger wheel, coil pack, EDIS, sensors, brackets and leads, I have decided to go for a Megajolt. It is overkill I'm sure but about the same price, given I had the other stuff.
I hope Tony is OK. I tried to call him today and it went straight to message. Did he get hit by the floods last month?
M
PostPosted: Thu May 11, 2017 8:29 pm
Online
Looking at his Facebook he might be on holiday
PostPosted: Sun Sep 10, 2017 1:03 pm
Black box needs 10V or more to work.
I had the same problem, recognised by accuspark. They sent me a switch and loom to bypass it. However, since refitting my Lucas starter I've not needed to use it.
See the other recent thread for details. When I rebuild my son's car it is getting a 35mm2 battery cable.
On the recent Rylstone Rally the temperature in the morning was minus 5deg C. My car was not happy starting and another car with a black box refused to start via starter but immediately started via roll/clutch start. We realised later this was due to voltage drop probably causing the black box to not operate during cranking.
I know I could rewire the box direct to the battery and set up a relay, but these were really extreme conditions. Just wondering if a solution would be if I carried a small 12v battery that clipped to the coil during startup under these circumstances?
PostPosted: Sun Sep 10, 2017 2:53 pm
There is an accuspark fix for this Phil, I can email you the diagram they sent me. It's a toggle switch that bypasses the black box during starting.
PM -
Edit give me mobile as it's on my phone.
PostPosted: Sun Sep 10, 2017 3:45 pm
Online
Can you send it to me too please? As Phill mentioned mine would only start that morning via roll start, it's very difficult to start in the morning at any temperature. It normally only starts to run when you let go of the starter..
I've got 6 degrees of timing via the blackbox at idle. Would it be worth advancing the distributor to 6 degrees and knocking 6 degrees off the timing map for easier starting bypassing the blackbox?
I'd like to get a multimeter on the coil and see how much voltage I'm getting during cranking...
PostPosted: Sun Sep 10, 2017 4:28 pm
Tim,
Just set the dizzy locked at TDC, on bypass it will start and run at that. Then flick switch to run. I will SMS you the schematic.
PostPosted: Sun Sep 10, 2017 5:59 pm
Tim,
So the motor should start easily enough timed at TDC? I was thinking along the same lines as Tim and locking it at normal idle timing.
Is the issue that with low voltage there is no spark because the box is not sending any signal?
PostPosted: Sun Sep 10, 2017 6:28 pm
The issue is the initial sparks and timing are provided by the dizzy module up to 200 rpm. However if voltage falls below 10V the black box doesn't let this happen. The bypass takes the box offline until you flick the switch to run.
Bypass kit was provided by Accuspark after I complained about the problem.
Mine started at Rylestone fine without the bypass, however I had gone back to the Lucas starter as it draws much less than a Gemini (350A!) does. I also have a big 640CCA battery. ;)
PostPosted: Mon Sep 11, 2017 7:18 pm
Pics-
(Edit) Black box is now NLA, even from 'Convertible Mini'.
Toggle switch is an on/on type.
Last edited by drmini in aust on Sun Sep 17, 2017 10:29 am, edited 1 time in total.
Users browsing this forum: timmy201 and 156 guests
