It is currently Mon Jul 21, 2025 9:38 pm
Post new topic Reply to topic  [ 41 posts ]  Go to page Previous  1, 2, 3
PostPosted: Sat Feb 25, 2017 8:14 am
Firefirey wrote:
Thanks gtogreen1969
Great photo's and engine detail.
You have a lot of info and I always enjoy reading your posts
Would like to know who own's the the white Cooper S if pos to ask about further detailing engine bay.
I may have a lead on some caps so fingers crossed.
Thanks for your help.
Pete.
68Rusty has the original white car. viewtopic.php?t=90224
davem has one also but ex police.
I don't know who owns the restored white car but here is a photo of the car. Someone else maybe able to assist.
PostPosted: Sat Feb 25, 2017 11:21 am
gtogreen1969 wrote:
Looking at these photos the Coil HT lead appears to have a heavy sheath around it.
I assume it's the radio suppressor you are referring to. To my knowledge it first appeared with the MK II Cooper S coil lead which is part AYH9680. I was fortunate to pick up one of these NOS a few years ago.
PostPosted: Sat Feb 25, 2017 11:23 am
Thanks Doug. I was thinking it was something like that but didn't want to give anyone a bum-steer.
PostPosted: Sat Feb 25, 2017 12:02 pm
I've already mentioned and others have confirmed that a variety of plug leads and caps appear to have been used across the BMC range, including the Mini. The parts books are of marginal help with pictures, numbers and change points.
Below are some engineering drawings for plug leads that may have been used. The First Used On field variously shows YDO9 (Nomad), ADO16 (Morris 1100) and ADO17 (Austin 1800), but that doesn't automatically exclude the Mini range (YDO4, 5 & 6). I've posted these so others can continue the discussion using factory documentation.
The plastic clip that keeps the four plug and single coil HT leads neat is this one. It was fitted to every MK II S I've owned and presumably other vehicles as well. You can see it in some of the engine bay photos. You'll see it says First Used On the Mini Matic.
PostPosted: Sat Feb 25, 2017 6:54 pm
Thanks Doug.
This is sure a very helpful subject now
Getting a lot closer now to an answer and maybe a purchase.
Pete.
PostPosted: Mon Feb 27, 2017 8:43 am
Has anybody got some photo's or information on the Australian Clubman GT spark plug caps/leads which they think are original.
Looking for a set if you have any spare
PostPosted: Mon Feb 27, 2017 10:43 am
These are apparently from a Clubman, although, as mentioned earlier, the same style was used on the Marina and P76. You can see some have the protruding ridge, some are stepped and some are straight.
It would be nice to identify the manufacturer. I'll ask on some Leyland FB groups.
PostPosted: Mon Feb 27, 2017 11:13 am
I have seen that style on a few 1971 MK2 Cooper Ss as well.
PostPosted: Mon Feb 27, 2017 2:16 pm
One of the P76 guys has these leads and plugs on his Targa. He doesn't know the manufacturer.
PostPosted: Wed Apr 19, 2017 2:59 pm
I assume the leads mentioned in the following Parts News Newsletter from March 1970 are the solid plastic capped ones described above.
PostPosted: Wed Apr 19, 2017 7:15 pm
Thank you Doug.
Users browsing this forum: Phil 850, watsupskip and 76 guests
