It is currently Mon Jul 21, 2025 9:22 pm
 Post subject: Carby removal
PostPosted: Sun Apr 16, 2017 3:56 pm
Is there a special type of Spanner required to remove the bottom bolt fixing the carby to the manifold? I've had this off before so maybe it's just a lack of caffeine not allowing me to think straight.
 Post subject: Re: Carby removal
PostPosted: Sun Apr 16, 2017 4:01 pm
a small one. :-)
PostPosted: Sun Apr 16, 2017 4:51 pm
Small and bent?
PostPosted: Sun Apr 16, 2017 6:31 pm
Stubby spanner , or an old 1/2" ring /openender ground down :idea:
PostPosted: Sun Apr 16, 2017 7:15 pm
Thanks peterb and goodie. I'll give a stubby Spanner a go. I was sure it was a 9/16 size though.
PostPosted: Sun Apr 16, 2017 7:27 pm
nah they are 1/2" well mine are
PostPosted: Sun Apr 16, 2017 7:58 pm
For one of the nuts in my setup...Take out speedo and undo it from the passenger seat :)
I'm sure this doesn't help answer your question and for that I apologise.
PostPosted: Sun Apr 16, 2017 10:22 pm
That's the beauty of working on minis.....you gotta remove various unrelated parts to access and remove the one you want.......... :twisted:
Cooper S Mk2
Cooper S Mk1
PostPosted: Sun Apr 16, 2017 10:29 pm
If its a 1 1/4" carb it is 9/16" AF that's required
1 1/2" Carb uses smaller stud so 1/2" AF
PostPosted: Tue Apr 18, 2017 9:23 pm
The original early Haynes manual recommends cutting the correct sized spanner (er, but not lengthways) in half for this job.
PostPosted: Tue Apr 18, 2017 9:44 pm
Try working on a Mk2 Jag and see how easy jobs are. Mini's are a soda.
The only easy job on a Mk2 is removing/replacing wheels (Knock off wires). Everything else is a PITA.
Yes, I was stupid to buy one.
PostPosted: Tue Apr 18, 2017 9:47 pm
Thanks everyone. I've had the carby off before but for the life of me can't remember how I did it. I'll buy a cheap Spanner and butcher and bend it if I have to.
PostPosted: Fri Apr 21, 2017 7:00 pm
It seems to be most English cars are like that.
Brad
During the day I work on English designed cars & on my own time I work on English designed cars....
Users browsing this forum: timmy201 and 85 guests
