goodie wrote:
Thanks for that Doug , i would be interested because it's different to the Austalloy type that i have ,
in that it has 2 sets of studs , one with shorter threads ( fine thread ) where you attach the stud to the flywheel , and 2 crankshaft buttons , one of which is attached to the centre bolt and doesn't appear to be able to removed , has anyone else seen or use this type of puller ?
I'll get some pics of the 2 pullers side by side tomorrow and another one of the backside of the Litchfield one to show the difference
the part No: on it is E 5410 .
I just had another look at the pics in your bulletin Doug and seen that there are 2 different types of pullers .
Litchfield were the Australian manufacturers and distributors of BMC and Leyland service tools. They also had their own tools to do similar jobs. Your E5410 is a Litchfield tool. If you look at the catalogue page I posted you'll see there isn't an equivalent BMC number.
BMC's tool for flywheel removal and many other pulling jobs is 18G304, or 18GA304 for the Australian tool, which is shown just above E5410 on the page.
Churchill were the UK manufacturers of BMC's service tools. On the following page from the Churchill catalogue you'll see the basic 18G304 tool is slightly different to Litchfield's equivalent. Also on the page below are adapters 304M (for coil spring clutches) and 304N (for diaphragm clutches). Those adapters may be the equivalent of the two sets of screws you mention.
