It is currently Tue Jul 22, 2025 7:21 am
PostPosted: Mon Mar 27, 2017 9:13 pm
Does anyone have any experience with Evans waterless coolant? A mate is looking to run it in his 1275 once the rebuild is complete.
PostPosted: Mon Mar 27, 2017 10:14 pm
I heave heard good stuff about it.. but not used it.
PostPosted: Tue Mar 28, 2017 4:14 pm
Milatsmadmini
Chong is using it and loves it, im still a little apprehensive about it all...
PostPosted: Tue Mar 28, 2017 5:21 pm
I did a bit of searching around before and it seems that the waterless coolant is essentially straight glycole.
On the plus side, it has a higher boiling point which means that it will cool better at high temperatures as it will stay liquid at temps where standard coolant/water will have created air pockets next to the cylinders. Therefore it will continue to draw away heat at temps where the water will stop being effective. Also it lasts virtually forever.
On the down side, the glycole is less efficient at transferring heat when compared to water. So for a given cooling system, water will extract more heat (as long as it is below the boiling point of the water).
So it won't make your engine run cooler, but it will handle being overheated much better and resist the change from "running hot" to "overflowing and going bad". And remain at "running hot" instead while still functioning to remove heat.
Sent from my Nexus 6P using Tapatalk
PostPosted: Tue Mar 28, 2017 7:04 pm
A mate of a mate used it in a bike and it was worse and took it back out
PostPosted: Wed Mar 29, 2017 5:45 am
The water/coolant mix has worked for me for the last 40 years, doubt I'll bother changing now. I don't know a great deal about it but popularity would say it's either too expensive or not up to the hype.
PostPosted: Wed Mar 29, 2017 6:02 am
I know of one instance where a race Mini didn't boil but got so hot the rings lost tension.
As said above I have had no problems with 25% glycol & water mix for the last 50 years.
If your Mini is overheating you have other problems. ;)
PostPosted: Wed Mar 29, 2017 9:51 am
I agree with the good Dr...
In 35 odd years, 6 Mini's including 2 rather souped up 1275's, I've never had overheating issues using water/ glycol mixture. (The main purpose of the glycol is the anti corrosion inhibitors).
Some of my driving has been in very hot weather;
Melbourne 42C days,
Driving Melbourne to Darwin via Perth in Summer,
Year and a bit driving in Indonesia including notorious Denpasar traffic jams when it can take half an hour to move a couple on km.
Never had the temp gauge go beyond 1/2 way in all those conditions.
My opinion is "Waterless Coolant" is an expensive fad and a complete waste of money...
67 Deluxe
Dry suspension
4 synchro close ratio gbox
Cooper S brakes, no booster
PostPosted: Wed Mar 29, 2017 5:18 pm
In the 60 & 70s we just used water in cast iron engines with copper radiators, no fancy mixing of exotic coolants, no glycol, nothing. And the servo attendant checked the level and topped it up every time you called in for petrol. East west engines with side mounted radiators were a real novelty.
Slide
1965 Mini Van (1360)
1970 Mk2 Cooper S (1310)
1978 Rover SD1 V8 (4.6)
PostPosted: Wed Mar 29, 2017 7:16 pm
There is a Jay Lenno's Garage Youtube clip on it. Probably a promotional thing, but it does explain it.
PostPosted: Wed Mar 29, 2017 9:17 pm
Those were the days. Young kids just out of school could get their first job at a servo. Not anymore.
PostPosted: Thu Mar 30, 2017 7:37 pm
I agree of people are using it to stop their car from boiling over, they are merely using a band-aid instead of fixing the issue.
PostPosted: Thu Mar 30, 2017 8:06 pm
I have used it in my 850 for the past three years with no problems at all, although it went in after the rebuild so was all clean and no water, you need to use the cleaning product before using the waterless coolant.
A very good product indeed if not a wee bit expensive.
Laurence
