It is currently Tue Jul 22, 2025 7:37 am
PostPosted: Mon Mar 13, 2017 2:27 pm
sitnlo62 wrote:
Every seat I have ever seen has had #10/32 unf threads sometimes incorrectly referred to as 3/16 unf.
#10/32 is a very common thread used on a Mini and all BMC cars of the era.
It seems the parts book and standards manual is correct this time, which is not always the case. :P
PostPosted: Mon Mar 13, 2017 3:08 pm
Just chatting to John Smidt and he mentioned having seen pressed metal wing nuts used for this application. I hesitated to mention it earlier but I'm almost certain the 1969 MK II S I purchased new also had this style wing nut.
http://uk.misumi-ec.com/vona2/detail/221005014083/
PostPosted: Mon Mar 13, 2017 3:45 pm
My late 68 MK 1 S has the pressed metal ones.
They are basically a speed nut with "wings".
At first glance they look like they may be solid but they are not.
The stud they screw onto is probably #10/32 tpi UNF but I haven't put a thread gauge on the stud.
RonR
68 build Mk1 Cooper S
PostPosted: Mon Mar 13, 2017 4:44 pm
The pressed metal type are apparently called American style wing nuts.
http://www.fastenerdata.co.uk/fasteners ... 869d3.html
PostPosted: Mon Mar 13, 2017 5:50 pm
RonR
Thanks Ron. Your car is close to mine and being a one owner car thats good enough for me.
PostPosted: Mon Mar 13, 2017 7:58 pm
Thanks everybody for your help and input.
One more detail down. Many to go!
Next time I will keep every single part !!!
Will try and hunt some down in the next day or two.
It is so pleasing to have this forum and it's members with so much knowledge to call on.
It's a big Thank you from me. :-) :-)
Pete.
PostPosted: Tue Mar 14, 2017 5:53 am
Mine are definitely UNC/whit, although it is a Wover mini. They're originals, I've had seats apart.
PostPosted: Tue Mar 14, 2017 1:09 pm
Hi
Can get the pressed wing nuts size 10/32 UNF through EDL Fasteners here in NZ. :-)
Users browsing this forum: acarseldine, Bing [Bot], justminis and 91 guests
