It is currently Sun Jun 22, 2025 5:21 am
 Post subject: crank q....
PostPosted: Mon Mar 06, 2017 5:17 pm
Can I use an A+ crank in a 1100s block ?
if yes, can I use "s" rods or will I have to use another kind ?
 Post subject: Re: crank q....
PostPosted: Mon Mar 06, 2017 5:37 pm
1. yes
2. not in standard journal size - A+ cranks have big journals (1.75" against 1.625" ?). You'd need to have the crank ground (stroke + or - or stay the same) - and I gather preserving the rolled fillet on those cranks is extra important
wait for Dr Mini or Mini Man....
PostPosted: Mon Mar 06, 2017 6:25 pm
cheers Simon,
521 / 177 { I think} are "s" rods, 1100 b/j have ugly lumps on the cap .....what id's an A+ rod ? as I might have some in the shed somewhere.
PostPosted: Tue Mar 07, 2017 11:36 am
A+ rods are lighter than the lumpy 1100S ones. However you can lighten those, I mill the lumps down by 8mm then do likewise to smooth off the lumps at little end. Finally clean the rest up with the linisher and die grinder. [edit] and balance them end to end.
Good enough for a fast road motor.
A+ rods are/were common in UK, used from 1980 on in all 1275s.
