It is currently Wed Jul 23, 2025 7:33 am
PostPosted: Thu Mar 02, 2017 10:13 am
Just wondering how people have dealt with this part rusting?
I noticed m-machine list upper and lower but it looks like it's gonna be one helluva job getting them out!
PostPosted: Thu Mar 02, 2017 11:15 am
I had mine on a rotisserie and could not get in there, so I ended up cutting the mudguards off not far from the seam and along the right angle section along the top as I figured that it could be welded back into place with a lot of patience, but ended up putting on new guards as they had been damaged previously. There is a 90% chance that there is a lot more rust than you can see. Both sides on mine required replacing, made the upper brackets out of 1.2 gal metal. The headlight brackets and the front apron where it meets the headlights also needed replacement/repair which was much easier with the guard off. Wondered why whoever put the headlight bracket in place went mad with the spot welder, about 32 spot welds just holding that in place on one side :shock:
Graham
1974 Leyland Clubman
Lots of good machines
Of all the things I have lost, I miss my mind the most.
PostPosted: Fri Mar 03, 2017 8:39 pm
Thanks graham,
I'm hoping to replace it without removing the wings, they're almost perfect!
Ive ordered some brackets, hopefully my hands are small enough to get the job done :wink:
Users browsing this forum: Bing [Bot] and 89 guests
