It is currently Thu Jul 24, 2025 10:00 am
PostPosted: Sun Feb 26, 2017 11:44 am
Hi all,
Opportunities present themselves from time to time, and before I shop I would like to know if it is an east swap. I have a 77 Leyland Mini with the original 3 gauge cluster. Would the a Rover Mini cluster (such as is pictured below) be plug and play?
Appreciate your thoughts.
David.
"Evil will always triumph over good - because good is dumb"
1961 Mini 850 - sold 1997
1965 Mini Deluxe - sold 2013
1977 Mini LS - in build....
PostPosted: Sun Feb 26, 2017 2:22 pm
I think only the tacho wiring is different, if its out of MPI. easy way to check the rest is put the two side by side and follow the circuit 'tracks'.
PostPosted: Sun Feb 26, 2017 2:40 pm
Coil pack minis ran a different tacho signal, though the rest is very much the same.
PostPosted: Sun Feb 26, 2017 3:08 pm
Thanks guys.
Can the signal be converted?
Sent from my ASUS_Z017DA using Tapatalk
PostPosted: Sun Feb 26, 2017 5:21 pm
I have the dash from a late MPI Rover mini in my LS and it works fine. I can't remember for sure as it was some time ago but I think if you remove the tachometer there is an adjustment screw that can be turned tune it to your requirements. I think I connected up another tachometer seperate and adjusted the Rover one to read the same as it. I can't saw its 100% accurate but I believe it to be pretty close.
PostPosted: Sun Feb 26, 2017 7:20 pm
how did u get the fuel and temp gauge to work as there is no voltage stabilizer ??
PostPosted: Sun Feb 26, 2017 9:23 pm
it's build inside of the Rover/Nippon Seki gauges
Rover 214 atm ....
PostPosted: Mon Feb 27, 2017 6:55 pm
Ahhhh that makes sense go for it :)
PostPosted: Wed Mar 01, 2017 11:57 am
Thank you all for your replies. Apart from Tacho calibration - all seems plug'n'play.
Cheers, David
