It is currently Sat Jul 19, 2025 6:01 pm
PostPosted: Thu Feb 23, 2017 2:42 pm
Here's a comparison of the depth of both options
1960 Morris Mini Minor
PostPosted: Thu Feb 23, 2017 5:11 pm
Give Ash some flowers Nick .
ricksmini wrote:
Yeah I might be able to doc. I will have to have a look through this posts to have a look how he done it. The cable I have is fairly long.
See how you go but when Tadhg (user on here) was looking to do the same thing, he ended up getting a 90° drive off of someone that had a spare but it was the wrong threads to suit the speedo.
I ended up machining some different parts to suit the one he got:
I don't have a pic of it all together sorry. Just keep this in mind that not all 90° speedo angle drives are the same.
PostPosted: Thu Feb 23, 2017 5:25 pm
Wow that's a lot of difference minijcar. Did you do the conversion?
PostPosted: Thu Feb 23, 2017 6:01 pm
The one on the left is the new electronic speedo from smiths. The other is a standard speedo with a smiths angle drive we have recast
PostPosted: Thu Feb 23, 2017 6:07 pm
Ohk minijcar where did you buy it from?
PostPosted: Thu Feb 23, 2017 9:13 pm
Stuwey wrote:
Could use a 1:1 90deg speedo drive box and a longer cable? How Lillee here did it.
I have a Group-N sized weber box that makes all of this impossible :lol:
Lillee does too, so he also moved the speedo binnacle into the car. Years ago when I was a wee lad, there was a 2"? spacer sold for this very purpose.
PostPosted: Fri Feb 24, 2017 6:58 am
Timbo wrote:
simon k wrote:
I made my own, but used the original odometer tumbler - I don't like the digital display
I'm making one too. Mine will use stepper motors to drive the needle and to turn the odometer. I haven't decided what to do with the fuel gauge yet.
that's easy.... my fuel gauge is standard, but the temp gauge has a little servo in it with the needle glued on to the arm. Fuel gauge can work the same way
PostPosted: Mon Jul 24, 2017 10:36 pm
Has anyone fitted one of these yet?
I'm thinking of biting the bullet and putting one in my deluxe!
