It is currently Sun Jun 22, 2025 6:40 pm
 Post subject: 7 port heads
PostPosted: Thu Feb 16, 2017 10:43 pm
Are there any 7 port heads to stay clear of?
 Post subject: Re: 7 port heads
PostPosted: Fri Feb 17, 2017 10:58 am
No
PostPosted: Fri Feb 17, 2017 5:55 pm
TK wrote:
No
Not what I've heard...
Cheap ones are cheap for a reason.
PostPosted: Fri Feb 17, 2017 11:12 pm
Well you've made the call, do tell. What did Graham say?
FYI. Firsthand - I know of a cheap 7 port that is running around Brissy with no problens except for wheel spin.
PostPosted: Sat Feb 18, 2017 11:46 am
Hi TK,
Note:
I am referring to the Pierce A series 7 port alloy head here. Not the Arden, Elder, etc ones.
I am only the messenger so don't shoot me. :)
1. Hardness. They are too soft, alloy will pull down under head nuts at 40lb/ft. Don't go past 35.
2. The spark plug holes are M8, the only heat ranges available seem to be an 8 or 9 in NGK parlance. Tending to be too cold for a regular road car.
No, there is not enough meat there to make them bigger and get a wider range of plugs..
3. High lift rockers and cam will exceed valve lift allowed as the spring seats are high. Can't deepen them, there is insufficient material there.
Common solution seems to be cut the valves deeper into the head. I guess longer valves would fix, if available.
PostPosted: Sat Feb 18, 2017 1:11 pm
Messenger? so it's hearsay. Hmmm.
Re: Arden (8 port?) are not a bolt on option. Spend big and spend alot more.
Elder, who sells them?
!. Not a problem is it?
2. Spark plugs work fine.
3. Common solution? How common? I have heard of only one person doing that. Oh he mentioned it here on this forum. Anyway he sunk his valves before knowing of the MED valve caps, they work fine. Did you know that MED use and sell this 'cheap' head.
PostPosted: Sat Feb 18, 2017 2:07 pm
The only one I could find in oz are the ones from oz mini parts $3100. Are they any good? Also where to by elder heads from
PostPosted: Sat Feb 18, 2017 2:32 pm
Milatsmadmini
Give GR a call
PostPosted: Sat Feb 18, 2017 3:25 pm
Forum Graffiti
Re: Arden are not a bolt on option. Spend big and spend alot more.
I've seen quite a few photos of recessed head bolts and rocker posts. I think it was a Pierce head IIRC.
Why so salty?
PostPosted: Sat Feb 18, 2017 4:31 pm
Gr? Who's that dude
PostPosted: Sat Feb 18, 2017 4:33 pm
So you're not sure if it was a Pierce 7 port? I wonder what head it was. Can you share these photos and the stories from the owners?
Not salty, just giving facts and not publishing someone else's opinion.
I like facts not opinions.
PostPosted: Sat Feb 18, 2017 5:24 pm
Are the ones from oz mini parts any good. I don't want people to get upset.I wanna buy lol!
PostPosted: Sat Feb 18, 2017 5:58 pm
All I can say mate is do your homework. You're off to a great start by asking about it on this forum. Try using the search function. Get opinions, facts and first hand experiences. As you know by now, I'm a facts man.
I don't know of Oz Mini Parts but Minisport.com.au (Adelaide) sell a form of a seven port. Other sellers & other types of seven port available here I'm not sure about. You may want to consider importing, exchange rate might have some bearing on this.
Good luck.
PS. no one is upset. :)
PostPosted: Sun Feb 19, 2017 12:30 pm
A guy at work bought one of the Pierce heads. He got it to work ok but it took him ages and cost nearly as much again to get there. He had to get special valves (from GR) and rocker gear (from MED) and extra machining done on the heads. They're not simply a bolt on out of the box exercise. Maybe that's the reason why the MED versions cost so much more.
His is on a Clubman GT with the twin 40 Webers that came with them (are these the Spanish ones that come in the kit or the inferior knock offs?).
BTW Minispares have released a new alloy 5 port head in race/road specs
http://www.minispares.com/product/class ... 7RACE.aspx
Slide
1965 Mini Van (1360)
1970 Mk2 Cooper S (1310)
1978 Rover SD1 V8 (4.6)
PostPosted: Sun Feb 19, 2017 7:00 pm
I have never seen a equal comparison (same valves, springs, cam etc) between an iron 5 port and any 7 or 8 port head. Yes you will get more power from one of these as the designe will flow better than a 5 port but exact numbers or percentage are hard to come by IMO.
