It is currently Sat Aug 23, 2025 2:38 am
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 549, 550, 551, 552, 553, 554, 555 ... 568  Next
PostPosted: Sat Feb 11, 2017 12:03 pm
Painted my engine.
PostPosted: Sat Feb 11, 2017 1:11 pm
Milatsmadmini
impressive vice to hold nearly an entire engine upside down!
PostPosted: Sat Feb 11, 2017 1:16 pm
And colour co-ordinated spark plugs :P
PostPosted: Sat Feb 11, 2017 1:26 pm
Champion eh!
PostPosted: Sat Feb 11, 2017 1:29 pm
For those trying to view on an iPad or other device that won't let you rotate the image, here it is the right way up. :)
PostPosted: Sat Feb 11, 2017 6:02 pm
Made up a set of plug leads using NOS Champion WC 187 plug caps, as per the 1967 Mini brochure engine bay pic, - Very happy!
PostPosted: Sun Feb 12, 2017 8:16 am
I can see a problem straight off...firing order is 1, 3, 4, 2...yours wont work well like that :P :D
Nice connectors tho...
PostPosted: Mon Feb 13, 2017 12:48 pm
That's not the only problem.
Those leads look way to big for that car in the photo :shock:
PostPosted: Fri Feb 17, 2017 9:47 am
I got in the car to drive it to work today and blow out the cobwebs. Unfortunately the brake pedal went straight to the floor! Further investigation is needed when I get home this afternoon...
PostPosted: Fri Feb 17, 2017 10:05 am
Last update was a while ago but gaining traction now that work and life is settling down a bit.
Finished installing new donuts, Hilos and shocks front and rear. Cleaned inner guards and treated to a coat of paint. Regreased upper arm pivots. Starred building front hubs ready to do the disc conversion ...
Lost many kilos of skin and blood in the process, microhands required!!
Sent from my ASUS_Z017DA using Tapatalk
"Evil will always triumph over good - because good is dumb"
1961 Mini 850 - sold 1997
1965 Mini Deluxe - sold 2013
1977 Mini LS - in build....
PostPosted: Fri Feb 17, 2017 3:49 pm
Stripped all the stinking electrical tape off the front loom after fixing the interior light. Tightened the loops and tucks and tucked in the excess, wrapped it all in self bonding silicone tape. New spades all round. Looks much better!
Sent from my SM-G900I using Tapatalk
http://www.ausmini.com/forums/viewtopic.php?f=3&t=93352
If I'm carrying on like a pork-chop, I'm having a great time.
If I go very quiet there's a very good chance I broke something.
PostPosted: Sun Mar 12, 2017 7:25 pm
I picked up the Moke from Matt Read who has rebuilt the motor and box and done a few other things. Today I did an oil change on it and fixed the broken two-stalk column switches. I'm a little bit excited, now I can go cruising again without clouds of blue smoke, puddles of oil and a blowing exhaust.
I also spent several hours doing paintwork on the dark blue 850. That thing is going to be well sorted soon, shame it will have to go. Matt said the engine is second in line so the time is now for anyone who wants an 850 that is fully rebuilt to choose the specs of the 1275.
Having one of my 5 1275 engines running really well has really lifted my enthusiasm level!
M
PostPosted: Sun Mar 12, 2017 7:37 pm
Went to move it out of way, Doh, flat battery! Spider's have been running their homes on it I bet.
Might sell it, It's a shame seeing it that way. :cry:
PostPosted: Sun Mar 12, 2017 7:38 pm
dang , double posting :oops:
PostPosted: Sun Mar 19, 2017 9:15 pm
Finished re-building the drivers seat. My first attempt at upholstery and pretty pleased with the result. Blasted and powder coated the frame, new rubber seat base, new Pirelli webbing, new foam throughout. The vinyl is in great shape and I believe original which would make it about 50 years old. Hard to believe it has survived that well.
Users browsing this forum: No registered users and 249 guests
