It is currently Wed Jul 23, 2025 4:40 pm
 Post subject: help with wiring please
PostPosted: Thu Feb 09, 2017 10:20 pm
Milatsmadmini
so i got rid of my dizzy and coil and went megajolty, as such i now have a few wires without a home. What is the most acceptable thing to do with these wires, if +'ve can i place on alternator? if -'ve can i ground? I suspect one of them was power for my fuel pump and tacho.... kinda stumped with wiring. so lame. :oops: :oops:
PostPosted: Thu Feb 09, 2017 10:21 pm
Milatsmadmini
also... my alternator currently has 2 wires going into it. Thick brown going to his place and the brown+yellow. What else needs to be on my alternator? is a 70amp rover jobby
PostPosted: Fri Feb 10, 2017 7:55 pm
When you have wires that are no longer needed it is always best to terminate them and put in a harness plug and leave them visible and accessible in case you need to use them for something else in the future. Might save you time.
"Let us remove your "SHORTS"
Users browsing this forum: Majestic-12 [Bot] and 92 guests
