It is currently Sun Jun 22, 2025 9:24 am
 Post subject: Camshaft removal on A+
PostPosted: Mon Jan 30, 2017 12:00 pm
Ok..... So what am I missing??
Trying to remove camshaft from A+ 1275
Head off
Timing case off
Disy out
Disy drive pulled half out
Push rods out
How to remove lifters?????
Is there a retainer at rear of camshaft/oil pump?????
Thanks
PostPosted: Mon Jan 30, 2017 12:03 pm
Looks like motor must separate from gearbox, turn upside down to release lifters, pull cam, then access to lifters????
PostPosted: Mon Jan 30, 2017 4:24 pm
to remove them, you don't need to remove the gearbox, just gotta turn it upside down, then take the camshaft out, turn it back over and shake it a lot. They'll come out of the sump plug hole eventually...
Unfortunately it takes an awful lot of very lucky shaking to get them back into the right spot
PostPosted: Mon Jan 30, 2017 5:11 pm
Hahahah
Gold
