It is currently Tue Jul 22, 2025 6:43 am
 Post subject: ID this car
PostPosted: Fri Jan 27, 2017 6:57 pm
I saw this posted of a Facebook site and the responses were very confusing. The owner said it was one of the first wind down window minis in the country. I am thinking a late 850 that has had an engine transplant, re registered 3 years after originally sold and badged as a deluxe.
YMA2S1-5-3093 = a late Mini 850 YMA2S1 53093 around Oct 1964?
9WRUH 16075 = 998cc engine from a Wolseley Hornet or Riley Elf?
ETU064 = NSW rego from 1968?
 Post subject: Re: ID this car
PostPosted: Fri Jan 27, 2017 7:12 pm
G'day GTOGreen, this one is a tin of worms, but I'm pretty sure the ETU rego is from 1967, as I recall us buying two cars in early 1968 where the plate numerals went back to starting with an "A", & in 1966 my Mum bought a new car ENT, so 1967 seems to fit?
PostPosted: Fri Jan 27, 2017 7:22 pm
My 68 deluxe was aef270
PostPosted: Fri Jan 27, 2017 8:08 pm
My 68 HR was ERC (wollongong area)
PostPosted: Sat Jan 28, 2017 6:39 am
66 deluxe in Sydney was ANM...
PostPosted: Sat Jan 28, 2017 7:26 am
I wonder sometimes if the was registered at low turn around registry the sequence may not correspond with high turn over offices
PostPosted: Sat Jan 28, 2017 11:52 am
Any ideas on what the car is? I am presuming a late 850. Badged as a deluxe with a Hornet/Elf motor.
PostPosted: Sat Jan 28, 2017 12:31 pm
The motor is a mystery into why
PostPosted: Sat Jan 28, 2017 12:34 pm
After 50+ years anything is possible. I once bought a deseamed Deluxe with a 998A+ Rover motor in.
PostPosted: Sat Jan 28, 2017 12:38 pm
I think they said the rego receipt is from the late 60's.
PostPosted: Sat Jan 28, 2017 1:52 pm
The strange thing is it has a motor in it from a car we never had over here
PostPosted: Sat Jan 28, 2017 3:30 pm
If we assume the build number is correct at YMA2S1 53093 this would make it September 64 model. The correct engine should have been around 8Y/U/H 12600.
The current engine, at the date of the rego papers, number 9WR/U/H is interesting in that 9WR is definitely a 998cc Rilet Elf engine, someone has updated the 848cc to 998cc.
I replaced the plates on my first car early in 1969 and they were ARW, a chap I went to school with had an Anglia which was registered ESS in 1968
John Sneddon
0408 431 807
1963 Morris Cooper
1965 Morris 850
1968 Morris Cooper S
PostPosted: Sun Jan 29, 2017 7:10 am
could the engine have been a spare part one back then?
PostPosted: Sun Jan 29, 2017 7:55 am
Back then if you bought a NEW block or motor from BMC it had NO stamped numbers. I bought 2, a 997 block, and a Morris 1100S 1275 short motor.
I'd say someone's fitted a S/H Riley elf motor sometime after original registration., before 1967.
PostPosted: Wed Mar 08, 2017 1:30 pm
NZ engine?
67 Deluxe
Dry suspension
4 synchro close ratio gbox
Cooper S brakes, no booster
