It is currently Sat Aug 23, 2025 6:11 am
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 548, 549, 550, 551, 552, 553, 554 ... 568  Next
PostPosted: Mon Jan 09, 2017 10:35 am
Milatsmadmini
Finally made a loom for my Megajolt.
Installed new discs and pads and checked pistons over, hopefully motor back in car by end of the week
PostPosted: Sat Jan 14, 2017 4:09 pm
I went & collected one of my sets of sets I have in storage & put them in my garage & started cleaning some LP883's that I have but the 36 degree heat was too much for me to do much.
Brad
During the day I work on English designed cars & on my own time I work on English designed cars....
PostPosted: Sun Jan 15, 2017 2:12 pm
Got my `nickel rod welded' 1100S head back from GR, after he machined it and fitted a new exhaust insert, and recut all the inlet seats for Mk2S valves.
This head (from Goodie) had dropped a valve, trashed the chamber and exhaust insert. But it wasn't cracked, and it passed a 700KPa water pressure test after welding.
One more 1275 head saved... :)
However, I won't sell it. It is going on my son's 1310 Clubby motor.
[edit 1] pic taken before other seats were cut.
[other edits] details added.
Last edited by drmini in aust on Mon Jan 16, 2017 1:41 pm, edited 4 times in total.
PostPosted: Sun Jan 15, 2017 7:58 pm
Been a process eh Kev , but good to hear :D .
PostPosted: Mon Jan 16, 2017 12:00 pm
My dad is visiting from the UK so took him out on Saturday for a drive in the mini and let him have a drive also. After the drive we had a go at using my gunson colourtune to check the mixture and tune the carb a little. Turns out is was running a little lean so we made a small adjustment and I took it back out for a drive with the kids in Sunday. Seems to have made a difference as it ran very nicely on Sunday.
1972 Leyland Mini Clubman
2000 Honda CBR929RR
PostPosted: Fri Jan 27, 2017 8:18 pm
Cleaned and repacked front bearings, need new seals. Now cleaning CV joints ready to regrease with special grease, ready to install hubs to front suspension, after painting where necessary.
Mk 1 Cooper S 1965
If you could erase all your mistakes of the past
You would also erase the wisdom of your present
Remember the lesson not the disappointment.
PostPosted: Fri Jan 27, 2017 8:40 pm
Did a re-ring on the Mk 1 engine.
How I loath using piston ring compressors. Must buy a decent one, those $12 ones made from coil steel with a ratchet are crap.
(Probably another product from The People's Democratic Republic of China)
PostPosted: Sat Jan 28, 2017 8:47 am
Milatsmadmini
Finally fitted engine back into moke, all clearances are perfect EXCEPT for the exhaust, which is 5cm too far over the gear change hole, so need to trim and get a flex joint (or 2...)
So if anyone gets bored this week and wants to put a moke drive line back together feel free to drop in :D (Looks hopeful towards Chong...)
PostPosted: Sat Jan 28, 2017 5:15 pm
after snapping off the ball on the clutch arm 2 weeks ago ... I replace the arm, clevis pins, bearing and carrier. Figured do it right, do it once was the best way :)
No more road ranger changes .....
PostPosted: Mon Jan 30, 2017 11:46 am
Sorted the missing horn ring and fitted my
13" flat spoke Les Leston
....you just lost him his insurance bonus!
997
PostPosted: Mon Jan 30, 2017 12:35 pm
Classy!
PostPosted: Thu Feb 09, 2017 11:08 am
Swore at it, and said Ahhhhhhhhhhhhhh!! a couple of times. Bleeding the brakes and the 3 way banjo fitting on the firewall is leaking from the bottom (rear) line connection. Naturally you can't get your hand in there let alone a spanner. Enter excuse to buy some imperial crows foot wenches from fleaBay and I have successfully slowed it from one drop a second to one drop every 15 seconds. Now I am between the crows foot dropping off the end of the long extension and jamming on the nut. .....time for a coffee
David L
PostPosted: Thu Feb 09, 2017 4:47 pm
Milatsmadmini
Almost managed to start it!
....almost
PostPosted: Fri Feb 10, 2017 7:58 pm
Cleaned the engine Bay.....
PostPosted: Fri Feb 10, 2017 11:02 pm
Miraz wrote:
Cleaned the engine Bay.....Image
ops you cleaned a little bit to much off there.
Nick
Users browsing this forum: No registered users and 289 guests
