It is currently Wed Jul 23, 2025 4:43 pm
PostPosted: Wed Jan 25, 2017 5:13 pm
Anyone able to help to say or show how to pull the dash off in my 1978 Leyland mini van
PostPosted: Thu Jan 26, 2017 7:04 pm
which bit of the dash? the gauge cluster or the top pad?
haven't taken the dash pad off a clubman in 20 years, but there are 2 nuts to be removed at either end, accessed from underneath
PostPosted: Fri Jan 27, 2017 10:33 am
thanks Simon saw them needing more help now
PostPosted: Fri Jan 27, 2017 11:16 am
Haven't done it myself, but from what I've seen posted in the past you benefit yourself by removing the windscreen to do this job
PostPosted: Fri Jan 27, 2017 1:52 pm
I agree about the windscreen... I think you can remove it with the windscreen in place but its a pretty brutal affair ripping it out past the rubber seal at the bottom of the screen. I'm pretty sure I removed the screen last time... (it was quite a while ago....).
Cheers, Ian
Users browsing this forum: Bing [Bot] and 96 guests
