It is currently Sat Jun 21, 2025 5:00 am
 Post subject: Engine swap ideas
PostPosted: Mon Jan 16, 2017 11:53 am
Hey guys was wondering if I was doing an engine swap what would be a good swap open to any ideas just don't want to be cutting into the engine bay at all
 Post subject: Re: Engine swap ideas
PostPosted: Mon Jan 16, 2017 11:55 am
There is a section of the forum here full of engine conversions.
viewforum.php?f=23
Some on a UK forum too for inspiration (although they have different regulations over there)
http://www.theminiforum.co.uk/forums/fo ... nversions/
PostPosted: Mon Jan 16, 2017 11:56 am
http://www.superfastminis.com/ IF you would get it rego'd would be the other problem, there are alot of "Swaps" out there.
Nick
PostPosted: Mon Jan 16, 2017 12:26 pm
That definitely won't satisfy the 'not cutting into the engine bay' criteria.
Don't listen to what I am saying... just understand what I mean.
PostPosted: Mon Jan 16, 2017 12:28 pm
Depends on the kit you get actually. And what car you Start with
Sent from my SM-G930F using Tapatalk
Nick
http://www.vetech.co.uk/hayabusa/
Expensive but good :)
PostPosted: Mon Jan 16, 2017 12:34 pm
Are you talking about replacing the existing engine with another A Series engine of larger capacity, or installing a different engine from another make of vehicle?
What model and year Mini do you have?
PostPosted: Mon Jan 16, 2017 12:36 pm
i have a 1978 Leyland mini van and was thinking of swapping the engine
PostPosted: Mon Jan 16, 2017 12:40 pm
http://vtec.minimania.com/vtec-mini-conversion-kits.htm
PostPosted: Mon Jan 16, 2017 1:42 pm
Same kit as the Mini Tec/SuperFastMinis conversion linked above.
*witty signature*
Sapphire Blue Deluxe spread across three parts cars, two sheds and a driveway...
PostPosted: Mon Jan 16, 2017 1:55 pm
The other option is a 8v or 16v Bmw K series head swap.
viewtopic.php?f=20&t=94601
Have a chat to Mini man.
Nick
PostPosted: Mon Jan 16, 2017 6:59 pm
8) Can't think of anything better then a 3 cyl Daihatsu turbo, big block Honda Jazz or maybe the Micra conversion that mad matt the min man is working through 8)
PostPosted: Mon Jan 16, 2017 9:10 pm
1275 MG Metro engine won't need any bodywork whatsoever. :)
PostPosted: Tue Jan 17, 2017 1:44 pm
Keep in mind that if you're doing any engine conversion away from the A series engine, cutting into the engine bay will be one of the easier jobs. That is to say, an engine that doesn't need any cutting won't be much easier than one that does, so if you're looking to avoid engine bay cutting to make things easier, then it's really a drop in the ocean.
You will still need to fabricate the subframe, engine mounts, cables, drive shafts, clutch, transmission rods/cables and splice two wiring looms, and that's presuming there is no interference with the brakes or anything else in the engine bay.
PostPosted: Fri Jan 20, 2017 2:16 pm
True but an engine that doesn't modify the original monocoque might appear easier to revert back for originality. Not sure how the engineer views this.
I've heard CG13CE engines with the smaller 1.0l gearbox are fairly easy to fit, you don't need to cut wings and the radiator can be retained. However, many seem to go down the route of using the whole 1.3 package, which requires some bulkhead mods.
