It is currently Thu Jul 24, 2025 8:40 am
 Post subject: fuel pump
PostPosted: Fri Jan 13, 2017 3:43 pm
Hey All,
I'm pretty sure my mechanical fuel pump is leaking fuel into the engine.
recently the oil has started to smell a bit like petrol when i check the level (which I do weekly)
Should I replace it with a mechanical fuel pump? or get an electric one? and if electric, which one should I get?
Its just a 998 with a single HS4
Thanks!
1975 Hairy Lime/White Clubby
 Post subject: Re: fuel pump
PostPosted: Fri Jan 13, 2017 5:08 pm
I vote just fit a new pump, keep the mechanical.
PostPosted: Fri Jan 13, 2017 5:16 pm
Probably the quickest & easiest way .
