It is currently Thu Jul 24, 2025 3:35 am
PostPosted: Fri Jan 13, 2017 12:02 pm
hi all,
looking at selling 1100S block no caps, surface rust, looks like its been bored out (unknown amount) also, what should I be looking at paying for a Mk1 S crank (if anyone has one)?
PostPosted: Fri Jan 13, 2017 12:50 pm
your block, $100?
to buy an uncracked Cooper S crank 800 to 1000 if standard to 010.
PostPosted: Fri Jan 13, 2017 1:32 pm
I agree with TK.
Block would be worth much more with original caps. Like $350+.
Buying new steel caps and line boring it will cost a heap of money.
PostPosted: Fri Jan 13, 2017 3:29 pm
Watch what this block goes for.
http://www.ebay.com.au/itm/Morris-Coope ... SwjDZYdzls
Can't see any caps with it.
PostPosted: Fri Jan 13, 2017 3:35 pm
The numbers on that looks like the same guy who stamped mine, it's an 1100S Auto block.
PostPosted: Fri Jan 13, 2017 3:43 pm
Haven't seen that format before. 12H169 / H695.
PostPosted: Fri Jan 13, 2017 3:47 pm
The three numbers on the end are the serial number.
From way back:
Q for Morris 1100-
Maaaate, I have a block here from an 1100S auto, it's 12H169/H321
Any idea what vintage? :lol:
Jan 69 to May 69. Probably closer to Jan than May.
They only built the Morris 1100S automatic for five months and about 700 cars. The early cars had a fully imported powerplant with the 12H169/H and the later ones had the Australian produced one with the 12YA/A/H prefix.
PostPosted: Fri Jan 13, 2017 3:52 pm
I forgot about the early Auto Blocks. Mine was a later 12YEAH.
No mention of it being an auto block in the add.
PostPosted: Sat Jan 14, 2017 9:01 am
usually nothing wrong with auto blocks really
very little fatigue with these, old ladys driving to church on sunday etc :-)
all that`s required to change to manual is-->
an oil pump adaptor plate (which we have hundred of in stock)
fit said plate, drill oil gallery right through to meet said oil pump adaptor plate
remove oil-pressure reliefe valve "Seat" , fill both "through-holes" & re-fit
& drill dip-stick hole
also remove all the excess studs from base flange
it`s now a manual block :-)
easy-peasy
normally these 1300 auto blocks are either std or 020 bore so excellent for reco
Matt
0407 135 656
PostPosted: Sat Jan 14, 2017 12:19 pm
What Matt said ^^
I also found it needed a gasket between the oil pump spacer and the block.
Users browsing this forum: No registered users and 119 guests
