It is currently Fri Jul 25, 2025 9:35 am
PostPosted: Wed Dec 21, 2016 5:38 pm
Chipping away at restoring all the various parts off my car while I wait for the shell resto and the engine rebuild. I have done the hydro bags and was wondering how to tackle cleaning inside the hydro lines. Can it be done, do I just flush with something and see if they are blocked? A search didn't reveal any tips. Cheers.
Flute - 68 MK I Cooper S
Member: VMCI #2474
PostPosted: Wed Dec 21, 2016 9:26 pm
While the lines had hydro fluid in them they would have been free of corrosion since the fluid is corrosion resistant and protects metal surfaces very well. The outside of the pipes and connectors tend to corrode in contact with the air - and the presence of hydro fluid on steel parts seems to accelerate corrosion on them when exposed to atmosphere.
The pipes are bundy tubing like the brake pipes, made from several protective coatings layered over a steel tube so shouldn't have any serious corrosion or sludge blockages.
Push a length of whipper-snipper cord through them and flush with compressed air or garden hose.
I've never bothered cleaning the inside.
But since your parts have been sitting around, make sure you seal the ends of the pipes to stop mud wasps filling them or skinks getting in and dying.
PostPosted: Thu Dec 22, 2016 7:43 am
Great, thanks Bill. Now I am glad I asked because as simple as it sounds I hadn't thought of using whipper snipper cord! Cheers.
Member: VMCI #2474
PostPosted: Thu Dec 22, 2016 5:23 pm
Just remember to take it out of whipper snipper first, otherwise the motor might block pipe. :-)
PostPosted: Thu Dec 22, 2016 7:05 pm
This Lady rocks...I can still smell Bisley's 8)
https://www.youtube.com/watch?v=-DUCLdR3gvU
Hmmmmmmmm
http://sevron.co.uk/msds/bisley-gun-oil-msds-download/
PostPosted: Fri Dec 23, 2016 8:17 am
9YaTaH wrote:
Saw all the marks for copywrite and such and I was expecting an add like shamwow
Nick
PostPosted: Fri Dec 23, 2016 8:25 am
If you really think you need to flush them out I reckon hose them out then dry with compressed air would do it...
67 Deluxe
Dry suspension
4 synchro close ratio gbox
Cooper S brakes, no booster
PostPosted: Mon Dec 26, 2016 10:40 am
Thanks for above info.
Member: VMCI #2474
