It is currently Fri Jul 25, 2025 2:10 pm
 Post subject: Cylinder Head Finished
PostPosted: Sun Dec 11, 2016 1:05 pm
Well i have finished modifying this 12G940 Head from a 1100S morris
Ported and polished to what i think is neither too much or too little
New Valves and Bronze guides
Double valve springs
Exhaust seat inserts
MED 1.5-1 roller tip rockers
Extra holes drilled for Cooper S
She is all ready to be fitted
1970 MK2 Cooper S
PostPosted: Sun Dec 11, 2016 3:33 pm
Looks nice. Watch those bronze guides though, Minispares phosphor bronze ones tend to close up when fitted and need reaming. Then when run up to temp they can shrink further.
I had to ream mine, twice, with a 9/32" solid reamer. Once when built, then again when a valve started to grab. OK since. Now done 50,000 miles.
Other suppliers may have better bronze guides.. ;)
PostPosted: Sun Dec 11, 2016 4:49 pm
Hi Doc
Yes they got the reamer treatment as per the instructions that came with the guides
When you do it yourself it gives you a scene of achievement
That's until it craps out on you and you wish you had someone else do it :shock:
1970 MK2 Cooper S
PostPosted: Sun Dec 11, 2016 7:17 pm
You didn't get rid of the horrible bypass system after all that beautiful work :-)
67 Deluxe
Dry suspension
4 synchro close ratio gbox
Cooper S brakes, no booster
PostPosted: Sun Dec 11, 2016 7:33 pm
Looks great [SMILING FACE WITH OPEN MOUTH]
PostPosted: Sun Dec 11, 2016 7:41 pm
Very nice
1968 Morris Mini Cooper S
PostPosted: Sun Dec 11, 2016 9:16 pm
A bypass hose is fine with decent hose. I use Pirtek MPH 08, hydraulic return hose, ,500 psi.
With a brass nipple it should outlast the car. :)
PostPosted: Mon Dec 12, 2016 6:17 am
I like to keep things original looking
And my car didn't overheat even in hot weather
1970 MK2 Cooper S
PostPosted: Tue Dec 20, 2016 5:34 am
Here is the head with the extra bits on it
Seeing if everything fits
1970 MK2 Cooper S
PostPosted: Tue Dec 20, 2016 6:00 am
When we put these rockers on Jenk's S motor they needed 2mm packing shims under to get adjustment.
This was on a Mk1S head.
Nice rockers though! :)
