It is currently Fri Jul 25, 2025 2:15 pm
 Post subject: Flywheel Query
PostPosted: Thu Dec 15, 2016 7:14 pm
hi, I have a Mini flywheel that I had a new ring-gear fitted and clutch face machined. When fitting ring-gear, part of the flywheel broke away, as per photo. I was told it would not be a problem. They did not rebalance the flywheel. Any thoughts on the subject?
 Post subject: Re: Flywheel Query
PostPosted: Thu Dec 15, 2016 7:52 pm
That looks like a fair chunk, how did they do that?
PostPosted: Thu Dec 15, 2016 7:59 pm
If it was balanced before that fell out, it's certainly not balanced now !
PostPosted: Fri Dec 16, 2016 12:12 am
Boat anchor
PostPosted: Fri Dec 16, 2016 6:21 am
mickmini wrote:
Boat anchor
I agree, do not use this cast iron flywheel if you are going to rev it at all. That damage shown can cause further cracks which result in it's disintegration. And in a RHD Mini, it's right in line with your crown jewels...!!
PostPosted: Fri Dec 16, 2016 7:23 am
Take it back to the clown that damaged it (and gave you absurd assurance that "she'll be right mate") and get him to replace it!
67 Deluxe
Dry suspension
4 synchro close ratio gbox
Cooper S brakes, no booster
PostPosted: Fri Dec 16, 2016 12:16 pm
I agree with the Doc. Do not use this flywheel.
PostPosted: Fri Dec 16, 2016 12:46 pm
Thanks, this confirms my thoughts on the subject.
PostPosted: Fri Dec 16, 2016 1:28 pm
what a butcher! he must've pressed it on cold, the new ring gear is probably stuffed now too
PostPosted: Fri Dec 16, 2016 4:06 pm
May well have been damaged by a dill with a hammer "Previously"
i wouldn`t go accusing people of "Possible" "previous" damage only showing now after fitting a ring gear
just saying :-)
but in saying that, no i would`t use it either :-)
PostPosted: Mon Dec 19, 2016 3:09 pm
That is scary. If that was presented to someone who just accepted the advice because they didn't know any better the outcome could be........ wow, I really don't want to think about it.
PostPosted: Mon Dec 19, 2016 3:38 pm
The hub is OK, so take that out before you bin it.
Matt Read `TheMiniMan' has some nice lightened ones that bolt onto that hub. Fine for road use. But balance first.
PostPosted: Mon Dec 19, 2016 7:33 pm
If it was 'previously' damaged the so called repairer should have said before going to the trouble of grinding and fitting ring gear. If it shatters, is he going to fix the damage?
Users browsing this forum: Bing [Bot], GuamMini and 73 guests
