It is currently Sat Jul 26, 2025 10:27 am
PostPosted: Sun Dec 11, 2016 10:52 am
Can someone tell me what the thread is in the head for this bypass fitting
The one the connects to the water pump
I have a new fitting here that is 5/8" x 16 tpi and i can not find any reference to this thread
can someone confirm that this is the thread
1970 MK2 Cooper S
PostPosted: Sun Dec 11, 2016 11:24 am
Yes, it is an odd-ball. It is also used for the crankshaft bolt.
It is 5/8-16 Whitworth apparently, but I reckon a 5/8-16 UNS will be close enough even though the threadform is slightly different (55 deg v's 60 deg) given the low torque/load on the fitting.
I am about to change that fitting myself.... once my new tap arrives from China :-)
Don't listen to what I am saying... just understand what I mean.
PostPosted: Sun Dec 11, 2016 11:45 am
I drill the remains 9/16" then run a 5/8 18 UNF tap in, it takes hardly anything out (except the old fitting's thread). There are only about 3 or 4 threads in there!
I make new fittings from 5/8 UNF [RH] oxy hose joining nipples. Just turn one end down and shorten the other end a bit.
Never rust, last forever.
PostPosted: Sun Dec 11, 2016 12:43 pm
Well with the use of a thread file and a die grinder i managed to revive the thread and get the fitting installed
Only problem is that the fitting was just plain round and no hex
So a little butchery to get it screwed in
1970 MK2 Cooper S
PostPosted: Sun Dec 11, 2016 7:34 pm
The plain round ones that I have seen have two little notches in the hose end of them so you can fit a big screwdriver in and screw it in tight that way. You could mod yours with a hacksaw.
Users browsing this forum: TartanRed and 74 guests
