Morbo28 wrote:
winabbey wrote:
Most of the other Mini parts suppliers will have the kit. Here's one closer to home.
http://minikingdomonline.com.au/product ... -cylinder/Hi guys - this link winabbey posted. Am I correct in saying that this kit includes the famous cup spreader that everyone advises to fit to the new slave cylinders?
I'd like to install the spreader in mine, just need to find a source. I want to get other stuff from MKO so if this is it, it would be an easy click.
Edit: I just pmd Dr Mini as he has made them in the past, so that's another possibility I'm working on
This is what you are chasing.
viewtopic.php?f=2&t=90249Attachment:
In the photo below the top slave cylinder is a new repro type and it only has a flimsy seal spreader. One good thing is they have done away with the circlip. This allows the piston to move further out as mechanical pivot points start to wear. The bottom slave cylinder is original and has the large seal spreader. I just swapped the old seal spreader to the new slave cylinder.
